    2002 WS6 Trans Am
    Is anyone using Spohn uppper and lower A-arms on a 2002 TransAm?
    The parts are:
    Spohn Tubular Lower A-Arms (Item: 741 from their website)
    Spohn Tubular Upper A-Arms w/bushings (Item: 742 from their website)
    And if so, what shocks/coils are you using? Are you having any problems? Do you like them? I need to get front shocks and coils. I mostly drive this car as my daily driver. But, do like to corner pretty good. The last pair of shocks i had were not working for me.
    I just intalled the uppers.
    The lowers are supposed to be prone to breakage so I went with LG motorsport lower A-arms.
    Check out this thread for pictures:
    http://www.ls1.com/forums/showthread.php?t=17106
    2002 WS6 Trans Am
    Really? The lower Spohn's are prone to breaking? Like maybe on the mounting pertch where the bottom of your shock mounts? I bent the hell outta mine. Trying to get them fixed. If I can't I'll have to buy new ones.
    2002 WS6 Trans Am
    Are those solid bushings on the Lower A-arms? Did those come with the arms, or did you have to get them somewhere else?
    The lower bushing are a common replacement that the road racers use instead of poly/Derlim/1le bushings and yes they come with the arms:
    http://www.lmperformance.com/825/2.html
    They are called spherical rod ends developed first for the use in aircraft construction. Almost all the aftermarket companies including Sphon, BMR, UMI, etc have these bushings as a option for lca, phb, a-arms, etc.
    Like I said in the thread (linked above) I had read that the rod-ends were supposed to be harsh but I really like them as they are precise and stiff.
  1. For Sale: spohn rear adj. control arms del-sphere/poly combo for sale
    By godless-phoenix in forum Parts For Sale / Trade
    Last Post: 01-25-2013, 09:02 AM
  2. Lower UMI A-Arms
    By JoshieDoom in forum Parts For Sale / Trade
    Last Post: 12-15-2010, 06:01 AM
  3. BMR front LOWER CONTROL ARMS / A-Arms
    By 97ramsst in forum Parts For Sale / Trade
    Last Post: 12-15-2010, 05:59 AM
  4. Help: umi lower A arms
    By xmarkx in forum Suspension and Handling
    Last Post: 08-11-2010, 04:57 AM
  5. SPOHN Lower Control Arms - Adj. with Poly Bushings
    By Ziggs01 in forum Parts For Sale / Trade
    Last Post: 12-23-2005, 07:11 PM
