Thread: Faults to look for in a WS6?
02-15-2013, 11:01 AM #1Junior Member
- Feb 2013
- Canada
White- 2010 Camaro SS
Like the title says are there any usual faults to look for when buying a WS6 other than cracked door panels?
02-15-2013, 12:05 PM #2
Be sure to check the sail panel for signs of bubbling. This is due to
the factory adhesive coming through the paint finish and although
i seem to have been lucky i understand the only way to correct
is to either get a GM replacement ( good luck with that) Or perhaps
a 6 litereater replacement panel.
Sanding, prepping and re-painting will not work as it continues to do it's
work beneath the surface!!
Power window motors can be very sluggish and a fix can be had from a well known
company who supply a fix.... not sure if they are a sponsor here so i won't name them,
but i expect you'll discover them!
There is other stuff so i expect others will chime in.
Trev
02-15-2013, 08:52 PM #3Spaz is My Mentor
If i wasn't using my phone I'd give a direct link.
Look for the General Info sticky in this section. Click on it you will see a few threads about purchasing f bodies and some other info that should help.
IIRC the "chicken pox" effects 99'< cars maybe 00<. Same goes with the door panels.
Passenger window motor- every f body has this problem. There is a $40 fix and is simple to do.
98's are the only yr that the water temp gauge works. Also are suseptable to oil pump issues.
There is more but like I said look for the stickies and they will provide more.
02-16-2013, 05:47 AM #4
OP: I posted a reply in your intro thread with a link that details just about everything we know of. Good luck!
02-22-2013, 05:27 AM #5Junior Member
- Feb 2013
- Canada
Thanks for the replies and info.
02-22-2013, 08:57 AM #6Junior Member
- Nov 2012
- Roanoke, VA
Sebring Silver- 2000 Trans Am
Make sure it's a real WS6, don't ask me how I know to ask
. Check the door tag. Also check if the VIN on the door tag matches the VIN on the dash.
Help: C6 Corvette ABS and Active handling faults @90mph
By BigDz in forum General HelpReplies: 1Last Post: 09-02-2009, 01:52 PM
