Thread: 79 trans am swap
02-12-2013, 04:42 AM #1Junior Member
- Feb 2013
- iowa
black- 79 trans am
79 trans am swap
I have a 79 trans am with a 403 that I was going to replace with a 400 that I have. Problem is that I thought the block was good, turns out needs complete rebuild so I thinking of a ls1 swap instead. Can anybody suggest a model to look for or ones not to look for... I have been looking for 98-02 ws6 wrecked trans ams but have not been having much luck. How far do most people go with retros. Gauges? A/C? Rear end?
02-12-2013, 05:44 AM #2Former Mopar Man
- Jun 2011
- Branchville, NJ
You can go as far as your wallet will take you. For an LS1 I would go with Ebay.
02-12-2013, 01:28 PM #3
I like to use LKQ when looking for newer engines. Priced decent, warranty, and usually low mileage if you are patient and keep looking. They are all around the country in about every state, so what may not be where you live, can be located and brought in from another location which makes it nice.
I got my 80,000 mile 6.0 from a 2004 truck there, $1200 out the door complete with the computer, front accessory drive, complete wire harness, exhaust manifolds and part of the exhaust system, cooling fan, shroud, air intake etc. etc...basically a complete package. I couldn't beat it for the price no matter where I looked. They have 5.3's, and some aluminum LS engines as well, just have to shop around and find what you want.
If it were me, I'd grab the overdrive trans (and did) for the swap as well and do it all.
Your factory 8.5" 10 bolt will be fine and is plenty strong, I'd leave that be.
On gauges, I used the factory gauges and simply drilled and tapped the LS engine to accept the mechanical sending units. Pretty simple.
AC is where some run into problems. Since the compressor is mounted low it does cause fitment issues, and your 2nd gen Fbody is likely no different. Some will cut and box in the frame to make it fit. Saves a few bucks but you will still need to make lines, and it's a whole lot of fun when that compressor is burried
I prefered to use a high mount AC compressor relocation kit from Kwik Performance, which uses a new Sanden style compressor. Had some AC lines made and charged it up.
The rest is a piece of cake. There are several companies now that make headers and engine mounts to drop the LS right into the 2nd gens. Just make sure you use the same manufacture, as some headers don't criss cross with other engine mounts.
02-12-2013, 02:20 PM #4Junior Member
- Feb 2013
- iowa
black- 79 trans am
Just wondering why you would go with auto vs manual
Also my rear end is a 2.41 so I will need to do something with it also, just wondering if 4th gen would fit
02-12-2013, 02:49 PM #5
4th gen rear won't fit, that would be a step backwards anyway, you'll make quick work of the whimpy 7.5's they come with.
Stick with the 8.5 you already have and just do a gear swap.
If your car is a factory 403 then you have the auto trans. Much easier (and cheaper) to just keep it that way. If you find a 6.0 it will come with the 4L80E, it would be a bullet proof combo to run, nothing wrong with it.
If you want to go manual you have alot of options that way as well. T56 may require some floor surgery, you'll have to mount a hydraulic clutch setup (slave/master) or use something like a quicktime bellhousing that uses a mechanical linkage. You could also go the TKO600 route which is made as a retro fit kit with everything you need. Either way you go witha stick you'll need a 4 speed console for a 2nd gen that matches the interior etc....it just keeps adding up.
Not sure exactly what you want as an end result though so the amount of work and money is going to vary.
02-12-2013, 02:57 PM #6
I'm going as far as building LS2 with a Tremec TKO for my '67 Chevelle
There are some things you just can't test in a white lab coat.
02-15-2013, 07:10 AM #7Junior Member
- Feb 2013
- iowa
black- 79 trans am
swap
Has anyone ever swapped the entire interior from a 4th gen to a 2nd Gen trans am
02-18-2013, 11:52 AM #8Junior Member
- Feb 2013
- iowa
black- 79 trans am
guess not
Think I will try
Question: Trans swap
By 2000dreambird in forum DrivetrainReplies: 7Last Post: 02-19-2013, 07:46 PM -
Trans swap for swap
By [CJ] in forum DrivetrainReplies: 0Last Post: 08-12-2011, 12:11 PM -
Question: Trans Swap
By dmcwhorter in forum Automatic TransmissionReplies: 1Last Post: 10-23-2009, 09:53 PM -
96 TA WS6 with LS1/Trans Swap not complete
By Snakes4 in forum Vehicles For Sale / TradeReplies: 2Last Post: 10-10-2009, 04:47 PM -
Question: M6 Trans swap
By kool-aide in forum General HelpReplies: 10Last Post: 02-23-2008, 06:27 PM
