    Member BRANDON's Avatar
    Jan 2011
    perry,ga
    black with silver stripes
    2001 trans am ws6
    clear coating wheels
    i recently purchased some c6 z06 wheels,when i got them they were completely powdercoated black, with my car being black i didnt want all black wheels,i took a closer look at the wheels and noticed they use to be polished aluminum so i taped them off and stripped the powdercoating off of the lip of the wheel and left the center black,now i need to clear the wheels but not sure what exactly or how exactly i need to do this,the problem is the polished part on the lip,how will clear stick to this? i already wet sanded and tested a part and the clear isnt covering up the scratches from the sand paper,and im afraid if i use finer sandpaper the clear will not stick
    Unless you drive your car on salty winter roads (probably not often in Georgia) I would polish them and then hit them with a quality metal sealer -- something like Zoop's or 200 mph. The clear will eventually start to yellow and peel even if you do get good adhesion on the first try.
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    ^^this
    Member speedyWS6's Avatar
    Sep 2009
    U.K.
    2002 WS6 TA
    Yep,
    I had this issue with my WS6 polished rims... Stripped the factory clear and fully polished the rims
    all over.
    Everybody i took advice from said fresh clear will not stick well! Don't know what the factory process
    is but i went, after advice from GoFast908Z on here and went for a product called "Optimum Opti-Seal".
    It is a polymer sealant and really does work very well to protect the bare polished rims.
    Trev
  1. Question: Powder coating wheels
    By David Q in forum Wheels and Tires
    Last Post: 08-26-2009, 01:25 PM
  2. 3M Clear Hood / Front End Coating
    By erikzola in forum Appearance Section
    Last Post: 04-21-2008, 09:39 AM
  3. VHT Nightshade is on, wetsand before clear coating?
    By Arioch in forum Appearance Section
    Last Post: 10-03-2007, 06:31 PM
  4. clear coating the windshield valance
    Last Post: 03-16-2007, 02:31 PM
  5. clear coating in engine, please help
    By third_shift|studios in forum Showcar and Detailing
    Last Post: 11-19-2005, 03:23 AM
