Thread: Headlights on my Trans Am
01-25-2013, 04:24 PM #1
I have a 98 Trans Am today when i locked my doors my headlights opened
and closed repeatedly and one of them makes a humming noise..Has anyone else had this problem??
01-25-2013, 04:33 PM #2Spaz is My Mentor
The plastic gear in the headlight motor is stripping its teeth. You have 2 options of fixing. One is temp the other much better.
Opt 1: rotate the gear 180* this will allow the lights to work, however over time you'll be back at this junction.
Opt 2: there is a billet aluminum gear you can get that will fix it permenently.
Im on my phone so I can't post link, if no one else does before I get hm I post it for you.
01-25-2013, 04:43 PM #3
OK, Thanks ill check back later for the link Thanks again
01-28-2013, 06:01 PM #4
Google Rodney Dickman headlight gears. First Google search. The new gear is brass.
01-28-2013, 06:29 PM #5Spaz is My Mentor
Replacement Headlight Gear For 93-02 Firebird / Trans Am
here you go....
01-28-2013, 06:31 PM #6
Make sure you read the entire page. Not just "ok new gear is brass so I wont have to worry about it tearing up a gear." He tells you everything you need to do to prepp the gear and the headlight motor itself. Because if you just take out the gear and skip the rest you will destroy the metal gear just like the plastic one
01-28-2013, 06:32 PM #7
Loose housing is notorious for trashing gears also.
01-28-2013, 06:49 PM #8
Help: 99 Trans Am headlights out of sync
By danielh85 in forum General HelpReplies: 13Last Post: 03-17-2021, 12:43 PM -
Modern headlights are bad. And vs Firebirds and Trans Ams?
By clovenhooves in forum Almost Anything GoesReplies: 8Last Post: 04-05-2016, 12:05 PM -
'98-'02 Trans Am headlights (complete)
By HurricaneLS1 in forum Parts For Sale / TradeReplies: 0Last Post: 06-14-2009, 10:07 PM -
Trans am HID headlights 8K *New Orleans*
By HurricaneLS1 in forum Parts For Sale / TradeReplies: 0Last Post: 11-19-2008, 06:41 PM -
FS: 1998 Pontiac Trans Am - Ram Air Clone - Fixed Headlights with $10,000 in Mods
By Joey98ws7 in forum Vehicles For Sale / TradeReplies: 2Last Post: 03-06-2007, 04:43 PM
