01-22-2013, 04:16 PM #1
LS3 2001 WS6 build finally done, right
Got my red baby back from Torq 2 weeks ago. I live in South FL & was using a shop in North FL because of their solid rep. Upon getting the car back I had numerous issues which I have outlined here before. Poor low speed drivability, self revving, & consistent discharge of unburned gas & oil. Torq in Miramar, FL took the engine apart showing me scorched piston tops & cylinders which were bored unevenly. That blew me away as this a TSP LS3 stroker I had purchased. Also the cam was far too aggressive for a street car & the LS1 pcm was left in. They had the block re-machined & bored out further (now 6.7 liters!), installed coated pistons, & an after market LS3 pcm, which has much more adjustability & power the old pcm. They also figured out that GM didnt label the wiring correctly. The results are awesome. The car dynoed at 463rwhp (550 hp at the flywheel!) & is a monster throughout the rev band. Low speed drivability is greatly improved w/no turning off or self revving. If you are a car guy & in South FL, check them out. They treat their customers well. Cant wait to see what the car will do at PBIR in a few weeks. Thanks to Paul, Eric, & Roy at Torq!
01-22-2013, 04:27 PM #2
Sounds like a beast! Did you keep the A/C? Got any pics/videos? Your wheels on your avatar look pretty good
01-23-2013, 07:24 AM #3
Hi Edgar,
Still have AC & all stock radio, etc. Your car looks nice too! Hold on to it, these will be valuable as time goes on. All the best.
01-23-2013, 07:37 AM #4Junior Member
- Jan 2013
- Miami
Frank, thanks so much for the kind words. I just wanted to clarify that we installed an E67 (Camaro ZL1, Corvette ZR1, CTS-V) ECM (GMPP control pack) to allow for far greater control, faster processing speed's, etc. We set this up to work with all factory gauges (Tach, Speedo, Oil Pressure, etc) as well as the A/C still working. Additionally, converting this bad boy to drive by wire gives a much smoother and linear pedal feel compared to the horrid cable pedal these Fbody's have.
Thanks again Frank. The posting makes all the hard work worth while
02-12-2013, 05:52 PM #5
I really hate to thread jack but I tried to post my own thread asking this question and was met with no cooperation. Is there a way to use this E67 PCM in a 03-07 Silverado to have use of the 6l80/6l90 and a late model engine and still maintain the stock gauges and all other BCM functions? Sorry again for the thread jack
02-19-2013, 06:31 AM #6Junior Member
- Jan 2013
- Miami
The motor will require a 58x reluctor wheel and then we can make it happen with any TCM and full control of cruise, gauges, etc.
02-20-2013, 03:17 PM #7
The Twin Turbo Z06 LSX 427 build from Hell finally done!!
By extremecorvette in forum Forced InductionReplies: 14Last Post: 11-20-2020, 07:30 AM -
James's 2001 WS6 Street/Srtip build
By chevyoverford11 in forum Firebird / WS6Replies: 37Last Post: 10-04-2015, 07:06 AM -
Finally decided to join :) 2001 T/A WS6
By scorpioMEX in forum New Member IntroductionsReplies: 5Last Post: 11-08-2009, 01:39 PM -
FS: 2001 Camaro SS, Arctic White, SLP Build #1553
By toofazt in forum Western MembersReplies: 21Last Post: 03-30-2009, 02:49 PM -
2001 trans am build
By m.crabtree in forum Firebird / WS6Replies: 6Last Post: 08-10-2006, 07:14 AM
