Results 1 to 20 of 22
Thread: HVAC Delete panel installed
01-16-2013, 08:35 AM #1Senior Member
- Apr 2010
- Alabama
I installed my HVAC delete panel last night. It looks awesome.
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
01-17-2013, 01:47 PM #2Member
- Sep 2008
- indiana
pewter- 2002 ws6 trans am
Wow there is room back there. It would almost be worth losing the air just to be able to change plugs without looking like I was in a fight with a cat.
01-17-2013, 03:25 PM #3
03-30-2013, 08:54 AM #4dbl clutch'n like i shld
- Aug 2010
- Oklahoma City, Oklahoma
sebring silver- Y2K SS CAMARO
are you just going to run a loop on the two open spouts on the water pump since theres no longer a heater core for the hot coolant to pass through?
04-02-2013, 03:45 AM #5
04-02-2013, 04:36 AM #6Sold: LS1 '85 El Camino
- Dec 2005
- Laurel, Maryland
Welcome to the club
04-03-2013, 06:46 PM #7
04-03-2013, 07:37 PM #8
04-03-2013, 08:36 PM #9Senior Member
- Apr 2010
- Alabama
It's cool I am getting a ls6 block and possibly a cam swap out of it. I am trying to decide if I want the studs pointing into the car or into the engine bay. They are pointing into the engine bay atm. I just need to delete my cruise control and ABS now. I would do power steering as well but I want to road race my car.
04-04-2013, 04:35 AM #10
But for the fact that I really like AC on a hot day... mine would be gone as well.
04-04-2013, 05:10 AM #11
04-04-2013, 08:16 AM #12Senior Member
- Apr 2010
- Alabama
I have and it looks nice. It is the look I am looking for except I am thinking keeping the power steering for RR unless it isn't necessary....I would think it would be necessary with all the turns? How hard is it to drive without it, like turning and everything?
Jeff, T-Tops and windows work wonders
. That and not driving it on brutally hot days. The sweating will help with the weight loss and reduce trace times right? Not that I need to loose any but my car certainly could. So far my weight reduction mods are:!HVAC, WSQ hood (weighs only 10-15 lbs), Breathless Performance lights (weigh nothing compared to stock). I need to get them all wired up once I finish my engine swap.
I am also thinking about going back to stock wheels and grind my 4 piston brembos to fit. I have seen it done. That or 18s that don't weigh much over 17s. How much do the stock 17s weigh?Last edited by 98TransAmWs-6; 04-04-2013 at 08:35 AM.
04-04-2013, 08:33 AM #13Sold: LS1 '85 El Camino
- Dec 2005
- Laurel, Maryland
Once you're moving, it's as easy as having power steering. The only thing that sucks is parking. Also, the manual rack has a higher ratio gearbox, so the wheels move more for the same distance the wheel is turned. Lock to lock on my car is less than three revolutions as opposed to four with a normal car. Once my car is back on the road, I'll let you take her for a quick spin to see if you like it.
04-04-2013, 08:38 AM #14Senior Member
- Apr 2010
- Alabama
Wonder if there is anyway to disable the power steering to see if I like it. In the mean time although your car will probably up before mine
04-04-2013, 08:54 AM #15
Stock wheels and tires are around 55 lbs. each. I put them on the scale after buying a set of Bogarts for the track.
04-04-2013, 09:03 AM #16
04-04-2013, 03:57 PM #17Senior Member
- Apr 2010
- Alabama
I am looking at are 24lbs for the front and 28lbs in the rear shipped weight. Wow these are lighter in the front than stock or at least the tires am going with are. The front tires weigh 27lbs and the rears weigh 30lbs but they are 315s.With tires weight for each front will be 51 and 58 in the back that is pretty good for non forged after market wheels that are 18x9.5 and 18x11. I actually come out 2lbs lighter lol.
True. I only drive my car less than 1k miles a year so I think I won't really mind. But we will see.Last edited by 98TransAmWs-6; 04-04-2013 at 04:58 PM.
04-06-2013, 05:41 AM #18
Here are the wheel on the scale (I was off a bit on the stock wheel and tire) --
Stock:
Front runners (Bogart 15" x 4" with Hoosier front runners):
Rear tires (Bogart 15" x 10" with Hoosier QTP's):
04-08-2013, 10:05 AM #19
04-08-2013, 11:37 AM #20
Question: T/A Cluster & HVAC Control panel in Camaro
By fbodyNATION in forum Camaro / SSReplies: 1Last Post: 09-19-2011, 03:03 PM -
UMI Performance New Product- 93-02 F-Body HVAC Delete Panel
By UMI Performance in forum External EngineReplies: 0Last Post: 02-01-2011, 01:22 PM -
radio and hvac delete plate/s
By svc707 in forum Appearance SectionReplies: 5Last Post: 04-15-2008, 04:41 PM -
Just installed LTs w/ EGR delete
By Whiteboycntdnce in forum External EngineReplies: 12Last Post: 12-07-2007, 04:37 PM -
ANY PICS of HVAC/ headlight switch white face guages installed?
By greatwhiteZ28 in forum Appearance SectionReplies: 5Last Post: 05-23-2007, 04:29 PM
