Results 1 to 1 of 1
01-14-2013, 09:56 AM #1Junior Member
- Jan 2013
- South Charleston, WV
LS1 Swap 2000 Model Silverado 4L60E...will the trans hold up
Swapping an LS1 into my truck and debating on bolt ons cause I'm not sure the 4L60e could handle it in my truck. Using all the accessories, harness, intake, injectors(factory 4.8L injectors in my model are 3lbs larger than factory LS1 injectors), fuel rail and pcm from the current 4.8L which I had found metal chunks in its oil during a change. I have hp tuners so I'm remapping my fueling and timing parameters to factory LS1. Going to gut the stock cats on the truck y pipe. Debating on tuning it and adding any bolt ons because I am unsure of if the trans go towing shift kit will be enough to handle the LS1 in a full size truck. Any opinions on what to do would be helpful. I would like to not have to 4l80 swap the truck but if I have to I suppose I can. The LS1 has 60,000 miles and I'm buying it for a very cheap price.
Can a 4l60e be used in a early model camaro.
By Street Fighter in forum Automatic TransmissionReplies: 6Last Post: 09-20-2013, 05:13 AM -
Help: 3.4l swap to lt1 how hard is it? And will my 5 speed hold up
By Tealcamaro in forum LSx Retrofit and SwapReplies: 8Last Post: 08-31-2012, 06:13 AM -
Question: ls7 swap in 2000 trans am
By vinnie311 in forum Firebird / WS6Replies: 13Last Post: 12-10-2010, 07:00 PM -
4L60E trans swap s10 to tahoe
By dto in forum GM TrucksReplies: 3Last Post: 07-18-2007, 07:18 AM -
Anyone Swap GTO seats into Late model Camaro
By Stun'nSun'nZ28 in forum Camaro / SSReplies: 3Last Post: 08-31-2006, 08:16 PM
