    Junior Member The Machinist's Avatar
    Nov 2012
    washington
    2001 Camaro SS SLP# 2646
    problem with cavalier
    First off, I hope I am posting in the right section? Anyways my daily driver has been having an issue with sputtering between 1500 and 2000 rpm when I mash the pedal. I was thinking maybe fuel pump/filter but at highway speeds it cruises just fine. So that leaves ignition. Maybe coil or wires. I replaced fuel filter and plugs about a year ago. Btw the sputtering feels really violent at times and i noticed it doesnt do it when engine is cold. Any input would be appreciated.
    I take it you don't have any codes?
    Never a bad idea to clean the MAF with some CRC Spray MAF cleaner for starters. Any possibility you have a vacuum leak? If none of these easy fixes help, then it sounds like a spark or fuel issue absent codes.
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    If you do not have any codes they I would test for vacuum leaks and clean your MAF and throttle body.
    Nov 2012
    washington
    nope, no check engine lights. Ill try ckeaning the maf and tb thanks for the suggestions
    it never does it when cold? How long into the drive does it start doing it? The list of possibilities is actually fairly long. How many miles on the O2's? The reason I ask is the O2's don't control fueling until the coolant hits a certain temp ( not sure of the temp on the crapalier) so what you're describing *could* be bad O2's. Normally you will get some O2 codes when that happens though. I would exhaust the other options first....check plugs and wires ( you say you swapped plugs but didn't mention wires) and check your fuel pressure and things like that. Cleaning the MAF never hurts like someone else mentioned.
    Check the oil and coolant for cross contamination. Cavaliers are known for their head gasket issues on the 2.2 motors.
    Like Orion stated it's a long list that can cause the problems you're posting about.
    I hugged my niece the day she traded her's in.........
    Nov 2012
    washington
    Yeah unfortunately I am aware of all of the woes that cavaqueers have. But fortunately I have had zero problems with mine the whole year and a half that i have owned mine until now. She has just shy of 200k so I dont expect to not have troubles now and again lol. I like to keep the miles low on the ss so this is just my winter beater to get me to and from work.
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    This.
    Also, you can have stored engine fault codes without the check engine light coming on. Take it to the auto parts store and have them hook up the OBDII scanner and see if anything pops up.
    Nov 2012
    washington
    I have a preditor tuner I can scan it with
  1. Can you guys help with my Cavalier?
    By redrocketws6 in forum Domestics and Foreigns
    Last Post: 11-01-2010, 07:36 PM
  2. FS- 94 chevy cavalier
    By ls1blackbeauty98 in forum Eastern Members
    Last Post: 10-13-2008, 05:18 PM
  3. Fast Cavalier???
    By Y2K_CAMARO in forum Almost Anything Goes
    Last Post: 08-24-2008, 01:42 AM
  4. 2001 cavalier help!!!
    By JoshieDoom in forum Domestics and Foreigns
    Last Post: 03-23-2008, 11:24 PM
  5. Does anyone own a 98+ Cavalier/Sunfire?
    By Warbird in forum Almost Anything Goes
    Last Post: 08-24-2006, 11:33 AM
