Results 1 to 2 of 2
12-26-2012, 01:44 PM #1Junior Member
- Jun 2006
- Central Missouri
Change injectors when going to LS6 intake
Was planning on replacing an oil pressure sensor but has turned into LS6 intake and cam swap on my 2000 WS6.
My question is I bought an LS6 intake only and planned on swapping my rails and injectors from the stock LS1 intake
to the LS6. The cam I am changing to is a Texas Speed Sleeper cam and typical bolt ons. Will the 26lb injectors fly or do
I need to buy some 28lb injectors?
12-27-2012, 06:59 AM #2Spaz is My Mentor
Best bet would be to talk with the tuner that is going to tune your car or TS&P to see what they recommend.
Depending on the cams specs you might even have to go higher then 28lbs.
LS6 intake, PnP TB, Injectors, etc...
By onyx_rock in forum Parts For Sale / TradeReplies: 9Last Post: 05-10-2010, 05:03 AM -
wtb: ls6 intake, rails, injectors in so cal
By AndrewH in forum Parts Wanted / TradeReplies: 1Last Post: 12-04-2009, 05:01 PM -
LS3 intake w/LS7 injectors w/ rockers
By JayplaySS2 in forum Parts For Sale / TradeReplies: 0Last Post: 07-02-2008, 02:02 PM -
when to change fuel injectors?
By bgable in forum Internal EngineReplies: 18Last Post: 12-25-2007, 09:15 PM -
Ls6 Intake Injectors?
By mikes ss in forum External EngineReplies: 4Last Post: 12-05-2005, 01:39 PM
