Thread: Truck 10 bolt worth the effort?
12-16-2012, 02:13 PM #1
Just as the title reads. I have access to a truck 10 bolt with no ABS and drum brakes. Asside from being a 6 lug, is there any way to make it fit a Camaro with the torque arm mounts and 3 channel reluctor ring etc, etc, or is it even worth the effort? Is there any great advantage over the F body 10 bolt or is it better to just save up for a 12bolt or 9in?
12-16-2012, 05:24 PM #2None Shall Pass
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
With enough money and work, anything can be made to fit. That said, it'll take a lot of each to make that rear work. Save for a 9" or 12 bolt made for a f-body, would be my advice. You'll spend a lot less, and it'll be a much easier installation.
12-16-2012, 05:31 PM #3
Kinda what I figured. I think I'm going with a truetrac and aftermarket axles and see how long that lasts for now. I'm doing other things to the car that involves it sitting for a while so I'm not too interested in jumping into stuffing a big axle under it just yet
12-16-2012, 05:43 PM #4
If you can afford the extra coin, the WaveTrac is a more robust set-up than the TrueTrac. I have the Moser 9" TrueTrac as well and am putting a lot of power through it. To date I have not had any issues. Been running it for around 4 years now.
12-17-2012, 03:46 AM #5
They don't make a wave track for a 10 bolt or I would have one under my truck. I have a valuetrac in that thing and have had 0 problems. Not even chatter like the mfg. claims you will have with the cheaper version. If I ever go with a 12 bolt or a 9 inch I might consider the wavetrack but that truetrac rip off is working good for me so far. I don't think I will ever have one in my truck since they don't even make it for the 14 bolt either
12-19-2012, 04:44 PM #6
I misunderstood. I mentioned that because Walt mentioned going with a 9" possibly, and then you started talking about the TrueTrac. I didn't realize you meant putting that in your existing 10-bolt rear. Oops.
5.3...are bigger valves worth the effort?
By JROBINSON1016 in forum Internal EngineReplies: 1Last Post: 09-15-2012, 10:01 PM -
Roller Rockers worth the effort/money??
By Mr. D in forum Internal EngineReplies: 7Last Post: 06-19-2010, 08:47 AM -
Maximum-Effort Fourth-Gen10-Bolt
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 07-26-2007, 09:50 AM -
Pac It In - Gen III Truck Motor Bolt Ons
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 09-28-2006, 10:11 AM -
Will Truck Throttle Body Work? Worth It?
By JoeMack in forum General HelpReplies: 9Last Post: 02-03-2006, 01:54 PM
