Thread: slave cylinders
12-10-2012, 05:24 PM #1
slave cylinders
I'm just wondering why i'm going through them like candy. 5 in around 2 years
12-14-2012, 05:44 AM #2
- Oct 2012
- ardmore oklahoma
yellow- 2004 pontiac gto
which kind are you using. i know i got mine off ebay with my ls7 clutch package. and no problems yet.
12-14-2012, 05:48 AM #3
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
Have you replaced anything else when you replaced the slave cylinder?
12-14-2012, 01:13 PM #4
- Mar 2007
- Henryetta/Tulsa Oklahoma
I would replace the master with it this time, at least.
Have you replaced the clutch any of these times? If not, it probably wouldn't hurt either.
I have found out..... the hard way, that it is probably a good idea to go ahead and change out the clutch system all at once when you have these kinds of failures.
12-20-2012, 05:30 AM #5
hey man me and you are both on the same road here. my trans am has been going through these like a preist on little boys. i pulled my tranny bc i heard the input shaft could be the problem, but also may not be. my problem was as soon as i had a new tranny installed the slave cylinders kept going with the new install. i had a new clutch installed and then the car made it four years...then the slave broke again with only 25k miles on it. pulled it all back off and there were metal shavings ever where inside the bell housing from the old slave cylinder. then they put a new on in it and it popped only 2 miles down the road. im curreently tearing the tranny apart and im going to replace my fourth gear syncro, and replace the input shaft or the bearing that goes around it, plus i am going to replace that pilot bearing and the master cylinder...and if that doesnt work im pushing my car into a rivine and collecting insurance.
Help: 02 WS6 Misfire on all cylinders
By UT Trans Am in forum General HelpReplies: 11Last Post: 03-07-2015, 05:13 AM -
What happens in your cylinders
By SMWS6TA in forum Almost Anything GoesReplies: 12Last Post: 01-10-2013, 05:01 PM -
Textralia Exoskel w/ new master & slave cylinders.
By cam02ss in forum Parts For Sale / TradeReplies: 4Last Post: 02-08-2009, 09:07 AM -
master and slave cylinders?
By FastAssZ in forum Manual TransmissionReplies: 3Last Post: 01-19-2006, 02:40 PM -
Anyone replace Clutch master or slave cylinders?
By WS6speedpaul in forum Manual TransmissionReplies: 2Last Post: 11-02-2005, 04:23 AM
