    Dec 2012
    Round Rock, Texas
    Pewter (gold)
    Can't pass inspection
    I've had problem after problem with my car (2000 SS camaro) and now it's the catalytic converters that I'm having a problem with. Any advice would be great
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    I believe you can contact your local GM dealer for a warranty replacement. Otherwise, go with aftermarket cats. You're getting a check engine light?
    Is the car stock?
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    I don't believe the cats are still under warranty after 13 years. Aftermarket is the way to go. SLP has high flo cats made for your ride.
    Cats are no longer under warranty. Not even with the extended time they gave. I ran out of time literally just weeks after the extended warranty expired for my car. That was a while ago.
    Poway, Ca
    SOM
    2001 Z28 (Sara)
    Can you pass the visual in your state with aftermarket cats?
    In California you would not be able to.
    SteveC
    phoenix
    04 2500 4x4 crew cab
    You can get them tuned out of the computer for less than any replacement. They will not show up on a code check.
    - - - Updated - - -
    If you have to have the sniffer test done, then you will need cats.
  1. Throwing AIR code, how to pass inspection?
    By gashkerwin in forum General Help
    Last Post: 09-18-2009, 03:21 PM
  2. Dallas - Need to fix to pass inspection - where?
    By watson023 in forum Texas Members
    Last Post: 11-18-2008, 07:06 PM
  3. Can I pass inspection with long tube headers?
    By Kup98ss in forum External Engine
    Last Post: 01-26-2008, 04:36 PM
  4. nbm pass fender cd player, chrome zr1's (2), tan door panel pass
    By 1fastcamarosss11 in forum Parts Wanted / Trade
    Last Post: 02-17-2007, 09:47 AM
  5. Replies: 6
    Last Post: 09-23-2006, 05:51 PM
