Thread: B pillar
12-10-2012, 03:28 PM #1Junior Member
- Dec 2012
- Jacksonville, AL
Pewter- 2000 Camaro
B pillar
Hey can you guys tell me how to remove the trim on the b pillar on a Camaro?
Thanks,
Andy
12-10-2012, 04:33 PM #2Senior Member
- Oct 2008
- Coral Springs, Fl
Are you talking about the little triangle by the window?
12-10-2012, 04:34 PM #311 years of bangin gears
- Jan 2009
- North Jersey
Someone will chime in. I THINK you just have to pull it off. Don't quote me, though.
12-10-2012, 08:35 PM #4
The little triangle pieces are held on with double-sided sticky tape. You can just pull them off, but be careful because they are thin. Some people use a plastic puddy knife.
The "B" pillar is typically the molding between the front and rear window on the outside of the car on a 4-door car. Not sure what a "B" pillar would be on a Camaro though.
12-12-2012, 11:40 AM #5Senior Member
- Apr 2010
- Alabama
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
12-15-2012, 07:43 PM #6Junior Member
- Dec 2012
- Jacksonville, AL
Pewter- 2000 Camaro
I am talking about the pillar between the doors and the rear hatch. They are often painted the body color on V6 camaros, but are painted black on Z28s. Is it possible to remove that piece?
12-16-2012, 01:41 AM #7
12-16-2012, 02:25 PM #8Senior Member
- Apr 2010
- Alabama
Oh lol I was confused.
That is called the sail panel and it is held on with glue. The "easiest" way to remove it is with a heat gun and piano wire but beware it will most likely be butchered and most likely will need to be replaced for the reinstall. Just curious, why do you need to remove it? Is the sail panel bubbling?Last edited by 98TransAmWs-6; 12-16-2012 at 02:30 PM.
Wanted: Pillar Pod
By 1slowbusa in forum Parts Wanted / TradeReplies: 0Last Post: 07-31-2011, 02:30 PM -
Help: A pillar
By 2000dreambird in forum Appearance SectionReplies: 5Last Post: 08-02-2010, 08:00 PM -
A-Pillar
By Z28boy2000 in forum Appearance SectionReplies: 9Last Post: 06-17-2009, 04:33 PM -
tri pillar pod pics
By 01ls1ws6 in forum Firebird / WS6Replies: 2Last Post: 04-28-2009, 11:27 AM -
Pillar Gauge Pod?
By x10-wakerider in forum Appearance SectionReplies: 4Last Post: 08-24-2005, 04:20 PM
