Results 1 to 15 of 15
12-06-2012, 04:39 PM #1
Should I use a crossover for my front door speakers?
I just bought a set of Polk db 6501 component speakers for the front doors of my Formula. Should I use a crossover or just use the wires from the factory? If I should use a crossover, how should they be wired?
Thanks in advance for your help!!!!
12-06-2012, 06:40 PM #2Former Mopar Man
- Jun 2011
- Branchville, NJ
You can get the wiring diagram online from Polk. I think you have to use a crossover for the tweeter to work properly.
12-06-2012, 06:41 PM #3
A cross-over is a separate unit that controls the filter which you would need to buy to be able to filter any unwarranted low frequency you don't want going to your mid-range speaker.
Unless the speakers came with their own cross-over?
If this is your concern and they didn't, you could just use bass blockers in-line with the speakers. That would be an inexpensive route which would serve a similar purpose.Boost gets you laid, unless your name is Jon.
12-06-2012, 08:52 PM #4
There is a factory built in crossover. Make sure you remove it. It would interfere with the Polk cross over you should be using. If you trace the wires back about a foot, you will see a bulge wrapped in foam. That is the factory cross over. I tore everything out of my car and rewired everything. Stereo pounds now. You can see what I did in my signature below.
12-07-2012, 02:37 AM #5
Good info! Thanks!
So I do not need the wires going to the tweeter in the door, I just use the other 2 wires for the crossover that came with the speakers after I cut out the factory crossovers...
12-07-2012, 08:16 AM #6
If you are still using the factory head unit, then you will want to cut out the factory xover, then wire in the xover that came with your tweeters and not share power between the tweeter and the door speaker. If you are using an aftermarket deck, how you wire it depends on how many channels you are using. I have my xovers and tweets fed from the door speaker's power because I only have a 4 channel deck, and since it pushes 60 watts per channel, I am not using an amp. You will also need to match the ohm resistance of the speakers and the deck. I am not sure of the ohm resistance of the factory deck, but I am pretty sure it does not match the speakers you got. I ripped everything out and started from scratch, so I had no worries.
12-07-2012, 12:07 PM #7
Yea... I replaced my head unit, with an aftermarket Kenwood, when the factory one bit the big one! That is why I am replacing the speakers... The new head unit made the music sound better so I thought new speakers will make it sound even better! One thing leads to another. You know how that goes!
12-07-2012, 12:16 PM #8
Yes I do. When you get to the sub, don't forget a cap. Makes all the diff in the world. Saves your alternator.
12-07-2012, 02:01 PM #9
What is a cap and how does it work?
12-07-2012, 02:31 PM #10
He is speaking of a capacitor, which stores energy, to use during peak bass hits from your subs so they do not draw additional current from your battery.
12-07-2012, 02:35 PM #11
Gotcha! I was not going to install a sub, but after I replace the speakers it seems like I will probably go ahead and install a sub! What do you recommend for a sub in the rear hatch area? Is there a kit out there for our cars?
12-07-2012, 05:51 PM #12
Here is an example like what I use. I don't have the MTX brand, and I think I got mine for around $50 used. You can go crazy to your heart's desire, but for a recreational stereo, meaning not competition, a maxed out 8 in our cars will pound. This box is designed to fit on the shelf in the ttop storage area on the driver's side of the car. If you have a factory disc changer, it will fill that space. ThunderForm Pontiac Firebird Trans Am Custom Subwoofer Box w Free 10" MTX Sub | eBay
12-07-2012, 05:52 PM #13
12-08-2012, 03:10 AM #14
12-08-2012, 02:47 PM #15
i dont know, never traced it back.
Front Monsoon door speakers
By mcnoskyimages in forum Parts Wanted / TradeReplies: 3Last Post: 07-04-2010, 02:25 PM -
WTB your working front door monsoon speakers!
By 5abivt in forum Parts Wanted / TradeReplies: 9Last Post: 05-29-2009, 11:23 PM -
What speakers are in the door?
By xirxious in forum Stereo and ElectronicsReplies: 5Last Post: 11-08-2007, 04:20 PM -
Front door speakers filtered?
By Eagle in forum Stereo and ElectronicsReplies: 4Last Post: 04-03-2007, 06:02 AM -
Front door panel speakers
By Zboner in forum Stereo and ElectronicsReplies: 8Last Post: 03-24-2006, 12:52 PM
