    Nov 2012
    Lacey, WA
    Navy Blue
    1999 Camaro Z28
    will this setup work?
    On tire rack they have the American Racing Torq-Thrust M's. The front size is
    17X9
    45mm offset
    6.85'' backspacing
    5.475 bolt pattern
    245/45-17 rec. tire size
    Would 275/40-17's work with the 17X9's on all four corners? Its a 99 Z28.
    It recommended 17X10.5 for the 275's but would that even look right? Would there be any rubbing with the 275's on all four?
    Also what is the widest tire i could use on the 17X10.5's? Could i use 315's in the rear and 275's on the 17X9's in the front?
    99 Z: Lid, catback. 13.2@108
    Coming in dec. 315's, 4.10s, lts.
    Nov 2012
    Lacey, WA
    Navy Blue
    1999 Camaro Z28
    Add-
    I dont want it to look stupid, just kind of natural. I wouldnt mind running 275's on all fours if it would be the smartest for a mainly street driven vehicle.
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    The 275s might bulge slightly. I run 275s on my rear 9.5" wheels. I think there are members who run 315s on 10.5" wheels. I could be mistaken. Other members will chime in here.
    Indianapolis
    2000 WS6 6spd Hooker LT
    The factory size wheels are 17x9 with a 275/40 17. I don't see why it'd be a problem with those wheels, unless the offset or backspacing is an issue. IDK what the OE specs are for the wheels.
    Member devildogws6's Avatar
    Monticello MN
    2000 trans am ws6
    there would be no rubbing and those tires would look good on that rim go to the 10.5 like they say it would almost have the "stretched" look
    Indianapolis
    Factory 16x8's are 55mm offset and the factory 17x9's are 50mm offset.
    Found that info on this site. I'd say those Torque Thrust would fit no problemo. And they do look great.
    I also know that the 275/40 17 tires have an approved rim width of 9-10.5''. If you want the best possible wear from any set of tires, get some that are non-directional so when you rotate them (every oil change or 5k miles) you can rotate them (eventually) to all four corners. Obviously that could only be done with the same size tire/wheel combo, and not directional tires. For an F-body like ours, the front tires swap sides as they go to the back, and the rear tires go straight forward.
  1. will this wheel/tire setup work?
    By wvbrett in forum Wheels and Tires
    Last Post: 05-10-2011, 03:55 PM
  2. Is recall work warranty work?
    By RealLiveMD in forum Almost Anything Goes
    Last Post: 04-30-2010, 05:20 PM
  3. anyone else work a shitty shift at work
    By issues in forum Almost Anything Goes
    Last Post: 08-18-2008, 01:17 PM
  4. Will this setup work?
    By bgable in forum Wheels and Tires
    Last Post: 08-19-2007, 05:35 PM
  5. WTT: My 4L60E setup for your T56 setup!
    By 4birdman in forum Parts For Sale / Trade
    Last Post: 03-16-2007, 12:26 PM
