    Jun 2012
    florida
    Dimmer switch '02
    Anyone ever change the headlight dimmer switch on the steering column while its in the car. The manual talks about replacing it when the steering column is out of the car.
    phoenix
    04 2500 4x4 crew cab
    I wired mine to a lighted toggle next to the headlight switch. I tried to put in a foot switch, but the car almost started on fire, so, no foot switch.
    Not sure why you would have to pull the column. What page of the manual are you referring to?
    Jun 2012
    florida
    manual
    Depending on the year, its around 2-77 to 2-80 in the manual. This is the dimmer HI LOW switch on the side of the steering column. GM calls it a dimmer, I think you are thinking of the instrument light dimmer.
    I was with you on what you were talking about, just easier to ask what page as I also have the books for the '02. Sometimes things can be a little difficult to locate in those books.
    phoenix
    The switch is just bolted or sitting in a cup that is bolted to the driver's underside of the column. If you pull the plastic kick panel that sits over the clutch pedal, and look up, you will see it. It's white IIRC. It is actuated by a long rod that levers on your blinker lever.
    Jun 2012
    florida
    wires
    Turned out to be corroded wires near the front of the car. On one side of the car someone cut and spliced some wires going to the headlights. I thought that was strange, know I know why. Connector was good and full of grease, the wires were so bad under the insulation I could not even get solder to stick to it. Seems like every item low in that area goes bad due to water intrusion. ie the horns failed, air pump failed and headlight wires failed. Wonder if corvette owners have the same problems.
  1. Question: My gauges will not light up?? Dimmer bad??!!
    By SilverGuy98 in forum Firebird / WS6
    Last Post: 11-04-2010, 02:21 PM
  2. Pics of dimmer switch
    By weberje in forum General Help
    Last Post: 09-11-2010, 06:27 PM
  3. Headlight Dimmer Switch
    By Mecinoid in forum Firebird / WS6
    Last Post: 09-06-2010, 11:02 AM
  4. Dimmer wire. Wheres the easiest place to tap in?
    By Hi-Po in forum General Help
    Last Post: 09-05-2009, 09:27 PM
  5. Cheap High Beam Dimmer Switch Mod ...
    By Mecinoid in forum General Help
    Last Post: 05-16-2009, 11:08 AM
