    Nov 2012
    Minnesota
    Yellow
    2005 SSR
    Engine dimensions
    I need some external engine measurements such as length, width, height. Is there a drawing that has these?
    Specifically, I would like to know the distance from the center of the #1 spark plug hole to the bellhousing flange.
    THANKS
    Welcome to the site!
    I would have to check my manuals to see if any dimensional info is provided. Probably no way I could measure that accurately with the engine in the car as it is set back pretty far in F-bodies.
    Here is something I found that might answer some of your questions: Engine Dimensions Check out the third diagram down from the top.
    Nov 2012
    Minnesota
    Yellow
    2005 SSR
    Thanks...........that is a start. I printed it out and can scale the dimensions and get close. The diagram shows the right side of the engine. #1 is on the left side. Do you know how much #1 cylinder is ahead of @2?
    I'll probably need to find an engine (out of a car) to get an exact measurement.
  1. Stock WS6 Rim Dimensions
    By 2001ws6ta in forum Wheels and Tires
    Last Post: 04-10-2009, 03:50 PM
  2. headlight dimensions
    By BirdCountry02 in forum Appearance Section
    Last Post: 01-21-2009, 07:04 PM
  3. Dimensions for ls1,ls2,etc
    By doo540 in forum General Help
    Last Post: 03-04-2007, 07:03 AM
  4. What are the dimensions of an LS1?
    By slohybrid in forum General Help
    Last Post: 08-28-2006, 06:31 PM
