Results 1 to 13 of 13
Thread: Fabbed adj. torque arm
11-01-2012, 06:09 AM #1Junior Member
- Jul 2010
- STL area
Black- 01 z28
Has anyone made or heard of someone making their own adj. torque arm and if so, did you mount it to the crossmember or tunnel or what? I really think I can make one but I'm not sure where to start and haven't seen one in person to use as a guideline.
11-01-2012, 06:27 AM #2COTM July '09
- Jun 2008
- Annapolis, MD
BLK/BLK w/CGM Stripes- 2010 Camaro 2SS/M6
Just look at some of the designs available by UMI, Spohn, etc. I had a LGM on mine and it worked great for handling cos it was trans mount instead of body mount. Long pivot, better for handling/breaking, short pivot better for launching. Decoupled systems are best of both.
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2I like work. It fascinates me. I can sit and look at it for hours.
My Cardomain Site My Fquick site Custom Installs
11-01-2012, 07:34 AM #3
I made a custom adjustable torque arm on my Monza a few years back. Shortened it and made a mounting system inside the tunnel (removed it from the trans) so I could install a muncie (no torque arm mount).
If you are familiar with the Monzas (1975-1980) they are the predecessor to the 3rd and 4th gen F-body in rear chassis design, that's where it came from, just a much smaller platform.
11-01-2012, 07:48 AM #4M6 King
- Mar 2006
- WI
- Blog Entries
- 1
This is a saddle mount style as another mounting option. I'm not running it as I want to go decoupled with one, but it came with my 9".
11-01-2012, 07:55 AM #5
11-01-2012, 09:07 AM #6Junior Member
- Jul 2010
- STL area
Black- 01 z28
any of you guys have an example of a decoupled one? whats your opinions on whats best as far as adjustability goes? like a heim joint you can screw in or out for pinion angle or maybe some assortment of shackles with predetermined pinion angles based on the tire im running or somethin like that.
11-01-2012, 04:24 PM #7COTM July '09
- Jun 2008
- Annapolis, MD
decoupled torque arm
Unbalanced Engineering Camaro and Firebird De-coupled Torque Arm
11-02-2012, 05:10 AM #8None Shall Pass
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
The Global West Trac Link is a similar setup too. I run one on my car, and love it. Just a note, it doesn't work with the 9" without some fabrication. Not a major project though.
11-05-2012, 07:18 AM #9Junior Member
- Jul 2010
- STL area
Black- 01 z28
I think I've come up with a pretty decent design. When make my subframe connectors I will incorporate a cross member that bolts in and serves as a ta mount and driveshaft loop and helps with rigidity. Anyone heard if something like this before? Thoughts on how it may work?
11-05-2012, 08:28 AM #10COTM July '09
- Jun 2008
- Annapolis, MD
Yeah I've seen a setup like that and it also included a drive shaft loop. It was on a race car, so it was incorporated into the roll cage and wasnt removable, but there was enough space to get the trans out.
11-05-2012, 01:08 PM #11
11-05-2012, 04:10 PM #12Junior Member
- Jul 2010
- STL area
Black- 01 z28
What's your guys' opinions on adjustability? Are heim joints pretty easily accessible and affordable? I've never had to look into buying them
01-07-2013, 05:13 PM #13Junior Member
- Aug 2012
- Virginia
Midnight Blue- 2002 Camaro Z28
On umiperformance.com (UMI) they sell replacement heim joints and adjusters. I plan on building my own torque arm to work with an 8.8. I plan on buying the heim joints, adjuster, and front bushing from them. It is the cheapest/quality option I found. They make a quality product, so they are bound to be good parts to use for building your own.
I strongly suggest you make it adjustable by the way.
For Sale: umi tunnel mount torque arm brace and on car adj torque arm
By 99yellowz28 in forum Parts For Sale / TradeReplies: 3Last Post: 07-10-2011, 08:33 AM -
Critique my custom fabbed exhaust merge
By Hi-Po in forum External EngineReplies: 5Last Post: 02-28-2010, 08:33 AM -
Torque Thrust II's vs Torque ThrustM Chrome's??
By SteelmanLS1 in forum Wheels and TiresReplies: 5Last Post: 03-01-2008, 03:36 PM -
low torque
By skar in forum Dyno InformationReplies: 0Last Post: 04-23-2006, 06:27 AM -
Recieved my new Fabbed Valve Covers**PIC's**
By NA$TY-TA in forum Appearance SectionReplies: 11Last Post: 03-03-2006, 07:25 AM
