10-19-2012, 10:20 PM #1
AFR 205's + 224R cam + Ported 92/92 Fast = How Much RWHP??
What up LS1's. I'll be purchasing the AFR 205's and ported 92/92 combo this upcoming week. After a plethora of research there's no doubt, I'll be "doing it right the first time" with these heads (my first head purchase) and never looking back. I already have the 224R and full bolt on's with ARP rod bolts and high flowing oil pump.
Any experienced member's have a probable estimate of the RWHP this package will produce? I want to stay very streetable and make tons of power/torque under the curve. My 224R is on a 114 LSA. The objective is to produce betwen 400-425 RWHP. Thanks
10-20-2012, 08:56 AM #2
Just out of curiosity why are you going with the 205's and not the 210's. Other then the cam specs this combo sounds almost identical to a friend of mines.
2001 Camaro Z28 - AFR210 V2 Heads, JPH Cam, Fast 102mm intake, TS 100mm MAF, NW 102 TB, FTP 104mm lid, kooks 1 3/4 Long tubes, custom Y pipe w/dump, BMR LCA,TQ. Arm,PH bar, lca bracket,k member, Upper/Lower A arms, AFCO shocks
11.20@120MPH
459 RWHP and 410 RWTQ
2009 Stryker Blue Pontiac G8 GT
10-20-2012, 01:13 PM #3
Well I can't seem to find the 210's with 62cc's but there was a new 205 with 62cc's. Milling to 62 I know is some free horsepower, plus with the .040 thick cosmetic gasket my compression should be almost ideal. From what I have read the only difference between them is that the 210 has a lighter valve train. If I'm wrong on that someone please chime in.
12-02-2012, 12:32 PM #4
i believe you should be 425rwhp min., as long as your tuner knows what he's doing. consider a possible fuel injector upgrade if the duty cycle on your injectors (assuming stock) is 90% or higher. 42/lb hr injectors will suffice nicely.
personally, i want to say you might be around the 440rwhp mark. however, we all know cars respond to the same mods differently. good luck and enjoy the newfound power!
Fast 78 with shaner s3 ported throttle body!!
By zmg00camaross in forum Parts For Sale / TradeReplies: 1Last Post: 08-17-2014, 02:52 PM -
For Sale: FAST 102 TB , ported TB , spohn mounts, pro thane , Slp plu.
By lowrider095 in forum Parts For Sale / TradeReplies: 8Last Post: 02-14-2014, 06:07 AM -
Ported FAST 90mm with stock cam!
By LS1TOY in forum GTOReplies: 4Last Post: 05-20-2008, 01:13 AM -
ported fast intake
By 0utLawTransAm in forum Parts For Sale / TradeReplies: 26Last Post: 10-30-2007, 08:02 AM
