10-17-2012, 04:34 PM #1
considering 99 TA with 96k..any thoughts?
been looking at a 99 trans am convertible to play around with in the nicer weather[now that winters comin..] white with a white top.looks nice,paint appears decent and body overall nice.has ls1 with 96k on it. askin price is 6900,supposedly is a 3 owner car all local and one was a woman. anything particular i should go into detail about when givin the car a really good going over.im not real familiar with the trans am so im not sure what goes wrong with them alot. did have a 02 camaro that had the ls1 and 70k and had rear end probs and stereo was garbage! thanks for any info!
10-17-2012, 06:57 PM #2
Check for t-top leaking...Seems to be a major issue with lots of them (mine included)
10-17-2012, 08:18 PM #3COTM July '09
- Jun 2008
- Annapolis, MD
BLK/BLK w/CGM Stripes- 2010 Camaro 2SS/M6
usual fbody issues, which are few and none are major, most are just cheap build lol. Check to see it the headlight motors are original or need attention use to grinding/etc. Check power antenna.
The only place I've seen rust really start on these cars is between rear floorboard the LCA bracket attachment pointsI like work. It fascinates me. I can sit and look at it for hours.
My Cardomain Site My Fquick site Custom Installs
10-18-2012, 11:08 AM #4Spaz is My Mentor
He's looking at a vert.....
Op, these 2 threads should help you...
http://www.ls1.com/forums/f6/guide-buying-fbody-118628/
http://www.ls1.com/forums/f6/differe...y-years-27512/
Now with a vert I'd look hard at the rear qtr panels for any signs of body flex, make sure the top cover motor works well and check for any tears. Motor and tranny you should already know from previous experience.
if you do pick it up and it has no SFC's my first investment would be 3 point SFC's That way you'll have no worries of body flex.
Asking price doesn't seem to far off. I make the 3rd owner of mine and got it for $6500 with 108k miles 3 yrs ago.Last edited by SMWS6TA; 10-18-2012 at 11:10 AM.
10-18-2012, 02:25 PM #5
thanks for the info,i never thought of the headlight motors,not used to them flipping,seems like that is a breakdown waiting to happen! im sure the pinion seal is wet,all i ever seen has been anyway,not that concerned about that really,unless its leaving a puddle..body flex should be pretty obvious as stated in the guide to buying a F body,i didnt see anything noticeable. it appears to be completely stock as well,not even a k&n filter..which is probably a good thing knowing it wasnt modded and had the crap run out of it! hey smws6ta...any issues at the mileage your at?
10-18-2012, 03:15 PM #6
I bought mine with 120,000 on it 2 years ago for $6200.
Best $6200 I have ever spent,I have had a blast with it
2010 Camaro SIM 2SS/RS A6
1999 TA A4 NBM
12.265 at 110.52mph
10-19-2012, 09:06 AM #7Spaz is My Mentor
currently has 166k miles and still running strong. Knock on wood....... Of course I've done a "little" mod work with mine
see signature. In addition to my 8.8 rear project I have a LQ4 short block in storage that is my next major project. I plan on keeping the LS1 and look for a classic car or truck to throw it into.
If I ever get a Vert I know I wouldn't be doing all that I have on this one. A vert would be my cruising car.
If you do get her, I strongly suggest the SFC's.http://www.ls1.com/forums/f7/my-6-liter-build-174257/
6.0L Block - Forged 403ci
, Polluter Stg3 Cam, FAST 102mm Intake, NW102 TB, MSD wires, NGK TR6 plugs, Truck Coil Packs, LS3 Fuel Injectors, CC Pacesetter LT Headers, TS&P ORY, QTP e-Cutout, Magnaflow Muffler, 104mm Air Lid & Line Lock, Catch Can, Stage 2 T56 w/Viper shaft, PRO 5.0 Shifter, Tick MC, SPEC Stg3+ Clutch, QT SFI BH, MWC DSL, Full UMI Performance Suspension, Viking Coilovers, YR1 Snowflake Wheels wrapped in NT555 tires & Custom Fab Ford 8.8 rear w/Wavetrac Diff 3.93 Yukon Gears, WSQ Hood, 3"CM Strange Eng Drive Shaft.
Your thoughts on...
By 67CamaroRSSS in forum Political / Debate ForumReplies: 8Last Post: 08-19-2015, 11:31 AM -
Thoughts on this car?
By Full Metal Jacket in forum Camaro / SSReplies: 16Last Post: 04-09-2010, 01:18 PM -
Thoughts on this cam???
By amoulds58 in forum Internal EngineReplies: 36Last Post: 09-15-2008, 06:51 PM -
New G8 any thoughts???
By 10-8-TA in forum Domestics and ForeignsReplies: 6Last Post: 04-05-2008, 12:02 AM -
Thoughts?
By third_shift|studios in forum Almost Anything GoesReplies: 49Last Post: 03-12-2008, 07:54 PM
