    Dec 2010
    Upstate, SC
    1999 camaro
    Just ordered some 4.10s!!!
    Just purchased a set of 4.10 gears and install kit from ws6store. Can't wait til they get here and I can get them in! I've had a bad case of the "mod bug" and just realized today that I had thought about getting a set a long time ago and never did. So now I have something to do to improve it a little.
    Just thought I would share!
    USA
    Velocity Yellow
    2008 Corvette Z06
    Be careful with launching the car with the stock 10 bolt in... More so if you have an M6 car. Those rear ends are the fbody Achilles heel.
    Dec 2010
    Upstate, SC
    1999 camaro
    I know..it's really just a street car. Its never seen the track and most likely never will. Its not daily driver status anymore.
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    You will like the difference with those gears installed.
    Dec 2010
    Upstate, SC
    1999 camaro
    Good to hear...I can't wait!! They should be here friday.
    Import Killer SLP00blueSS's Avatar
    MIchigan
    YES! I have the 4.10 in my M6 and LOVE it!! first gear is useless under WOT but, its a FREAK out of the hole. like was said, dont launch to high of an rpm cause if she does stick you will be putting parts of your rear end in a plastic bag. Good luck with the install!
    Feb 2007
    San Diego, CA
    2002 Z28 A4 NBM
    Sadly now demodded :(
    I'll only say this once: NEVER put $$$ into a 10 bolt!
    My car is an auto and for what I spent on multiple 10 bolts I could've bought a 12 bolt or a 9" (probably an S60)...
    Sig is before the demod.
    67 Camaro: K-K + 797-z (look it up), 454/Th400/4.10 12-bolt = 6mpg, PS/PDB/PW tilt, tach, gauges...
    Carbon footprint? CLOWN SHOE!
  1. i ordered these...
    By jiveass in forum Appearance Section
    Last Post: 02-19-2011, 03:43 AM
  2. Just ordered these
    By 10spokess in forum Camaro / SS
    Last Post: 04-20-2010, 10:00 AM
  3. ordered QTP's which Y to buy?
    By MnLS1 in forum External Engine
    Last Post: 03-18-2008, 05:17 PM
  4. just ordered
    By Z28_SS in forum Camaro / SS
    Last Post: 06-24-2007, 04:28 PM
  5. Just Ordered Another G.t.o.!!
    By 05gtoautoX in forum GTO
    Last Post: 03-19-2006, 05:00 PM
