Results 1 to 11 of 11
Thread: Seals
    Jun 2012
    florida
    Seals
    How often do you guys remove your t-tops. I read that you are suppose to use silicone on the seals. Is that the spray kind or the jelly type? I never have removed mine fearing they would leak.
    never removed them and you live in FL, how?!?!
    I take mine off all the time and have no leaks. Haven't used silicone either. My seals still look good.
    Arizona
    We rarely ever take ours out either. They don't leak but I doubt they would even if I removed them more frequently. The rubber is still in excellent shape. I go over the seals with a dressing like silicone you mentioned usually once a year. That's about how often they come out
    phoenix
    04 2500 4x4 crew cab
    Shame on you Firebird. The weather is perfect up there to take them out for almost half the year. Down here, I like to take mine out in the winter, and cruise around with the heat on. Perfect. Heat at your hands and feet, cold in your face. And, the op was wondering how to apply it. Spray or wipe on.
    Arizona
    Quote Originally Posted by az gt eater View Post
    I much rather prefer to press the button and watch the top go down in the other car
    Member Redrokit8's Avatar
    Aug 2011
    Roseland NJ
    Pewter Silver
    2002 Trans AM WS6
    I'm another one of those. 2002 WS6 and the tops have NEVER been off !
    Magnaflow Quad Tip, Lid, SBellow
    UMI: FTC, FSB, RSB, LCA's, PBAR, SFC's, T-Arm w/relo, D/S Loop
    Kooks LTH, 3" YP, H/F Cats
    Custom Grind Cam, Stall, 3:73 rear
    Bilsteins w/Strano Springs Conti Super Contacts
    TuneByFrost MSD Wires
    Cross Drilled/Slotted Rotors w/Ceramic
    Jun 2011
    Montgomery PA
    78 & 99 TA's
    Use dialectric grease. Sparingly.
    Pittsburgh
    2008 Hummer H3
    I push a button too FBJ!
    It's about 2" dia. Says, "A/C"
    Member SuperSSguy's Avatar
    Jul 2012
    NorCal
    Sunset Orange Metallic
    2002 Camaro SS M6
    Living in sunny California its a no brainer i take them off whenever its not freezing cold or raining which is alot! I use silicone spray and have no leaks what so ever!..Funny thought came to mind! I picked up my car new at the dealership and it was december cold outside and clear enough to see the stars but also cold enough to see the steam coming from your mouth i was so amped up on my new SS that i just picked up so i put on a big jacket tore off the t-tops and went for a cruise..people were looking at me like i was crazy!! But i didnt care i was in heaven cruisin in my new SS with the tops off on a cold december night........
    Jul 2012
    NorCal
    2002 Camaro SS M6
    Quote Originally Posted by johnfin View Post
    I do know that the manual shows how you should take them off and on- DONT take them off and drag the panel off at a level angle! you put them on/off at a 45 degree( or angled at least) angle so you dont wear out the edges,those are the pieces that will wear out and leak.
    I use spray silicone on T-top and door seals around once per year. I usually spray it on, wipe it off to get all the nasty stuff off, and then spray it again with a light coat. If your aim is good and you use a piece of cardboard, a folded up newspaper, or something similar to block the overspray as you go there won't be any mess.
  1. Question: rear seals leaking
    By JayTA98 in forum Drivetrain
    Last Post: 05-03-2011, 05:43 PM
  2. Valve seals
    By BadAZ in forum Internal Engine
    Last Post: 02-16-2011, 03:17 AM
  3. a/c line seals, where to get em?
    By DADillac in forum General Help
    Last Post: 07-08-2008, 08:35 AM
  4. A/C condensor seals
    By smoknponcho73 in forum General Help
    Last Post: 10-17-2007, 06:59 PM
  5. Comp 918's, retainers, seals, etc...
    By Mr. Luos in forum Parts For Sale / Trade
    Last Post: 09-05-2005, 02:59 PM
