Results 1 to 10 of 10
Thread: which motor mount should i get?
09-11-2012, 02:13 PM #1Junior Member
- Jul 2012
- Va
Black- 94 Z28
Does anyone know of any good motor mounts for 94 z28 im trying to replace my old ones with the bracket any ideas
09-11-2012, 02:33 PM #2
09-12-2012, 07:44 AM #3Spaz is My Mentor
look for poly mounts.
Prothane has some good products.
Summit has them for $52
09-12-2012, 11:28 AM #4Junior Member
- Jul 2012
- Va
Black- 94 Z28
Ok ill look for those thanks ill give updates on how its going for now i managed to take off the nuts and the bolt driver side but still worried about jacking it up fron the oil pan i lifted the engine from a side where a ridge sticks out works but not the most secure place ive been told to place a thicker bigger piece of wood to act as a cusion ill try this today but the last thing i eant is for me to go out and buy a new oil pan
09-12-2012, 11:47 AM #5Spaz is My Mentor
use a 2x4 that is a little longer then the width of the pan. This will even distribute the load and not focus it on one point.
09-14-2012, 04:33 AM #6Junior Member
- Jul 2012
- Va
Black- 94 Z28
Ok ill try that today thanks and if i were to buy the poly. . Motor mounts would it lower or raise the motor
09-14-2012, 07:02 AM #7Just a farmboy
- Jun 2007
- Montpelier, VA
Pewter- 2000 Pontiac Trans Am
neither, it keeps the motor in the same place, just the material is stiffer so it wont let the motor flex as much. you should change the transmission mount aswell, its just 6ish bolts to get to it. it should take about an half hour.
09-17-2012, 03:50 PM #8Junior Member
- Jul 2012
- Va
Black- 94 Z28
So i took the motor mount driver side its a stock part made by anchor and i ordered nre inserts now im trying to reuse the brackets can i bec its darn hard to take them off from inside the bracket and if not r there any motor mount out there bec i cant find any for my 94 z28
09-17-2012, 03:51 PM #9Junior Member
- Jul 2012
- Va
Black- 94 Z28
Oh and i got the poly mounts from summit
09-18-2012, 08:34 AM #10
Don't know if the '94's are the same as the '98's and up. But on mine I had to drill the rivets out of the clamshell put the new mounts in and then bolt it together. The new mounts came with instructions and bolts.
Help: motor mount
By new2dgame in forum External EngineReplies: 38Last Post: 03-14-2011, 05:31 PM -
motor mount
By V8MUSCLE in forum General HelpReplies: 2Last Post: 02-18-2010, 10:34 PM -
Motor mount ?
By brian r in forum General HelpReplies: 9Last Post: 06-22-2009, 03:36 AM -
Motor Mount help
By cm2papa in forum External EngineReplies: 0Last Post: 10-27-2008, 08:27 AM -
Motor and Tranny Mount Help
By kool-aide in forum General HelpReplies: 23Last Post: 01-01-2008, 09:43 AM
