Results 1 to 10 of 10
Thread: TB Bump Stop Mod
09-05-2012, 06:00 PM #1
TB Bump Stop Mod
Does anyone have a sticky on the TB Bump Stop mods?
09-05-2012, 06:16 PM #2Senior Member
- Oct 2008
- Coral Springs, Fl
File down the bumpstop and keep checking it on the car. You want to be around 4.6 volts at what i remember being the blue wire (don't quote me on that) If you go to 4.7 volts or above i believe you'll throw an SES light
09-05-2012, 06:27 PM #3
Here are the pics of mine showing before and after measurements and good view of the "step" that I filed into the bumpstop:
09-06-2012, 03:45 AM #4
Awesome! Thanks
For help guys! Can you elaborate some more on the 4.6volts?
09-06-2012, 05:34 AM #5Senior Member
- Oct 2008
- Coral Springs, Fl
One of the wire leads that runs to the throttle positioning sensor sends off a voltage signal, you should be able to stick the end of a multimeter through the back of the plug when the throttle body is plugged in. manually hold the throttle body open while you read the voltage, the more you grind down the higher the voltage will be when the blade is fully open. Ignition has to be on btw
09-06-2012, 06:03 AM #6
Thanks for the clarification! Doesn't exactly sound like something I want to screw up!
09-06-2012, 08:38 AM #7Senior Member
- Apr 2010
- Alabama
Do aftermarket TBs like my NW 102, need the bump stop mod?
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
09-06-2012, 09:41 AM #8
09-06-2012, 05:20 PM #9
09-07-2012, 10:50 AM #10
Bump stop ar-15
By bluehawk2000 in forum Gun's & AmmoReplies: 5Last Post: 03-07-2012, 04:44 PM -
WTB bump stop!
By Justin23454 in forum Parts Wanted / TradeReplies: 0Last Post: 02-01-2008, 06:27 PM -
help with bump stop mod
By RDS in forum Suspension and HandlingReplies: 9Last Post: 12-16-2006, 09:08 PM -
Bump Stop Mod
By KM02SS in forum External EngineReplies: 14Last Post: 09-12-2006, 06:45 PM -
TB Bump Stop Mod ??
By 98redbird in forum External EngineReplies: 0Last Post: 12-13-2005, 08:12 PM
