    Member My00Z28's Avatar
    Sep 2010
    Holland, MI/Lima, OH
    2000 Camaro Z28 A4
    Transmission shift Firmness HP Tuners
    Alright guys iv been messing with HP Tuners trying to make my Transmission shift softer under normal driving but no matter what i do it shifts hard as crap... any ideas?
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    Did you buy the car new ? If not, do you know if the other owners did any trans work ? Your trans may have an aftermarket or modified valve body.
    Sep 2010
    2000 Camaro Z28 A4
    No I didn't but I bought it stock. When I got it I don't remember it shifting this hard... I'm chirping 315s in to second gear at half throttle. Sig down low
    SLP lid w/K&N Filter, Free-Mods, LT-Headers, ORY-Pipe, V-Force Muffler, Frost Tune, AIR/EGR Delete, SFCs, Ported TB
    My00Z28-----2000/Z28--------2.0331---8.4118 @ 86.83----12.9856 @ 107.15----NA------10/11
    any codes by chance? Some tranny codes will command max line pressure. What have you done so far to try and lower your line pressures? You can probably get what you want by scaling the lower end of the shift pressure table down a little at a time until you get it where you want it.
    Sep 2010
    2000 Camaro Z28 A4
    No codes. I tried copying a trans pressure from another stock camaro along with the shift speed and 0 change? Am I messing with the wrong stuff? Does TM (torque management) affect firmness?
    yes.....it pulls timing to reduce torque on shifts. At low rpm though I'm not sure it's doing much......sounds like you'll want to use that shift pressure table since you just want to limit it at low rpm. Ideally you'd log that to see where at on that table you want to start/stop the scaling. Just remove a small percentage at a time until it shifts how you want it to shift.
    Aug 2012
    new york
    yes
    yes
    If you want technical information about your car performance or about its parts and accessories you could actually get access to this site. Plus you could post your questions and suggestions at this platform.
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    Quote Originally Posted by My00Z28 View Post
    Keep in mind that the commanded pressure returns a force motor current value that becomes the PCS duty cycle.... If it's something that *I* tuned I'd be happy to make a quick change if you email me your current file. If not, make sure that your FMC table is set back to stock and tune it from there.
    Sep 2010
    2000 Camaro Z28 A4
    Ya I got the mail order tune from you and iv been tinkering with it lately to get it to shift softer on part throttle but it won't change. Iv even tried stock trans tunes on it?
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    Is it a 'built' trans? In the trans diag portion, make sure the items that cause a fault to full line pressure are disabled as well.
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    I'm actually at work doing mail orders and a harness today; if you want to shoot it over in email int he next couple hours I can have a quick look and let you know if it's in the file or not..
    Sep 2010
    2000 Camaro Z28 A4
    No it's not built but I am at work till 7:30 so I probably will not be able to send it to you till around 8...
  1. Help: Transmission shift kit
    By DARK PHX in forum Great Lakes Members
    Last Post: 12-29-2010, 07:26 AM
  2. Adjusting shift firmness without messing up custom
    By fastlt196 in forum Computer & Tuning
    Last Post: 05-18-2010, 05:35 PM
  3. Vinci tuner shift firmness increase vs Shift kit ?
    By Formula in forum Automatic Transmission
    Last Post: 02-22-2009, 09:37 AM
  4. slp shift firmness improver
    By 94lt1ss in forum LT1
    Last Post: 10-19-2007, 06:13 AM
  5. Auto shift firmness
    By daveb91 in forum Computer & Tuning
    Last Post: 04-03-2006, 05:45 PM
