    Feb 2006
    How to install clear corners on Trans Am?
    Hey guys, I know this sounds like a really stupid question. I just got some clear corners from afterthoughtsauto.com. What are the steps to installing these? What tools do I need exactly. I know its pretty straight forward, but I just thought I would ask before I did it. It looks like the bolt holding the lense on needs a star wrench if I remember right, what size is needed? Thanks a lot for your help, and sorry for the stupidity lol.
    99FRC,00TA,98Formula
    91Firebird,88FieroGT
    you are correct. I do not know what size screw it is, but I just tryed a few different screw drivers and one of them fit. Once you unscrew them the lense comes out and the socket twists out. Then you just replace it with the clear corner and screw the lense in
    Member graphicsgod's Avatar
    Orlando, Fl.
    1999 Chevy Camaro
    It's not hard. Just take out your headlights completly. Then remove the lights in the turns, then the screws holding it in and it will just pop out. Put the clears in the same way you took out the olds.
    Rob
    Member Cobra2WS6's Avatar
    South Florida
    1999 WS6
    By far the easiest mod you will ever do. The correct size is T15 from the star bits
  1. Help: Clear Corners
    By Z28Nathan in forum Camaro / SS
    Last Post: 02-26-2011, 06:24 PM
  2. Blacked out corners or clear corners
    By Z28boy2000 in forum Appearance Section
    Last Post: 04-27-2010, 04:06 PM
  3. Clear corners install?
    By JwMonE99 in forum Appearance Section
    Last Post: 12-18-2008, 08:04 AM
  4. Clear Corners?
    By MarkuzLS1 in forum Firebird / WS6
    Last Post: 07-18-2007, 12:52 PM
  5. 98+ Trans Am clear corners & 3rd brake light?
    By MagicMan in forum Appearance Section
    Last Post: 08-06-2006, 08:06 AM
