Thread: Cam choice for 02 Camaro SS
08-22-2012, 12:30 PM #1Former Mopar Man
- Jun 2011
- Branchville, NJ
Ok, I finally decided to do a cam swap on my 2002 Camaro SS. I have only 33,000 nice miles on this car. While it has some bolt on mods and it has ran 12.78 @ 107 at E-Town I am looking for more performance without going too crazy. I figure I have about 345 rwhp but that is just a guess given the times I have ran and the mods I have. I have been looking at Comp Cams, Lunati and Texas Speed and I am dizzy over the choices. My current OEM specs are 197/207 @ .050 and .467/.479 lift with 116 seperation. I want to gain about 30 rwhp or so but I do not want to go too crazy. I figure something in the 224/224 @ .050 with a .565 lift with 114 LSA will meet my needs to keep the car drivable and reliable, so I figure with all the members of LS1.com who have already swapped cams I would like your opinion. What cam would you guys recommend ? I plan on replacing the oil pump even though it produces almost 80 psi cold and 45 - 60 psi hot at idle. I will also replace the timing chain, should I go double roller or keep the gears I have now ? I also plan on replacing the pushrods with hardened units. Do I use 7.40 rods or will I needs a different size ? last, Do I need to replace the valve springs ? While I do plan on hitting the track maybe two or three time a year and I do not drive like a teenager anymore. Also, I may do the work myself, how many hours am I looking at ? I have rebuild engines before but never an LS1. Do I need the JPR lifter tool ? Is there anything else I forgot ?
Thanks in advance for the advice and help.
08-22-2012, 12:56 PM #2Senior Member
- Apr 2010
- Alabama
With something like the 224 a double roller timing chain is overkill, and some oil pumps you can't use them because of clearance. I would just get the c5-r or ls2 chain. Unless you are changing heads you don't need pushrods that are different from stock length. I have a thread going that is called "Camshaft swap Howto" to give you an idea of the work involved. I am not done but close.
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
08-22-2012, 02:28 PM #3
Is this an auto? I'm guessing because of the initial tame cam specs you chose.
Since these engines have a non adjustable valvetrain,,,,sometimes longer pushrods are chosen with aftermarket cams for a couple reasons. Since it relies on pushrod length for proper lifter preload, pushrod length is important. I've seen some instances where people don't like the sewing machine sounds from an aftermarket cam and they lengthen the pushrods for more preload.
Another reason is because alot of cam grinders gain lift by making the base circle of the cam shorter,,,,this changes lifter preload and therefore pushrod length.
You can also change over to an adjustable valve train and adjust lifter preload on your own (my wifes LS1 is adjustable) then pushrod length becomes critical only to set valvetrain geometry. This modification is all personal preference though.
You'll have to talk to the cam manufacture of your choice and see exactly what they recommend for their particular camshafts.
08-22-2012, 06:31 PM #4
I know an LS1 will fit into my-is that the best choice?
By Primaz in forum General HelpReplies: 4Last Post: 04-29-2011, 06:06 AM -
Cam Choice?
By mike171562 in forum Internal EngineReplies: 6Last Post: 02-14-2011, 06:22 PM -
Cam choice
By bpk99ta in forum Internal EngineReplies: 8Last Post: 10-22-2009, 06:28 PM -
Cam choice, Camaro LS2
By 98redconv in forum Internal EngineReplies: 8Last Post: 03-01-2009, 09:38 PM -
Question: How is this cam choice?
By stevenm357 in forum Internal EngineReplies: 5Last Post: 05-28-2008, 05:26 AM
