Thread: custom exhaust
08-15-2012, 03:18 PM #1Junior Member
- Feb 2011
- Windsor, Ont.
Yellow- 2002 Trams Am CE
custom exhaust
my 02 WS6 is bone stock. I'm going with a true dual custom exhaust. I'm guessing I need to get my sfc's first, what else should i have done before i get the exhaust done. (eventually i want all the suspension done as well)
08-15-2012, 03:22 PM #2
If you want to do a tunnel brace, you prob want to get that done, as well as a rear end if that is in your future. The sfc's shouldn't get in your way, unless you want to tie them into a tunnel brace and d/s loop.
08-15-2012, 05:09 PM #3
Kooks makes a sweet looking true dual setup, but it requires the use of one or two aftermarket suspension components to fit.
02-18-2014, 04:08 AM #4Junior Member
- Feb 2011
- Windsor, Ont.
bump, i'm ready to start getting parts. Anything i need to do?
02-18-2014, 04:58 AM #5
Just plan it out so that whatever you do will work with future upgrades. If you go with an aftermarket aluminum driveshaft, it is generally larger in diameter than the stock one. Also, as already mentioned, the torque arm and tunnel brace setup will be your biggest obstacle. UMI and other manufacturers list which components will work with a specific exhaust setup.
Custom exhaust or buy a kit?
By StrikerWS6 in forum Firebird / WS6Replies: 2Last Post: 07-10-2009, 05:41 AM -
custom CME exhaust
By claytonr in forum Camaro / SSReplies: 3Last Post: 02-25-2009, 08:22 PM -
Custom Fab Dual Exhaust in NJ?
By Doom in forum External EngineReplies: 0Last Post: 08-07-2008, 02:42 PM -
Custom Side Exhaust
By jz28 in forum Camaro / SSReplies: 13Last Post: 05-16-2008, 09:06 AM -
Anyone in nc do custom exhaust work?
By sunsetorangess in forum External EngineReplies: 1Last Post: 01-28-2006, 09:37 PM
