    Member 02ragtop t/a's Avatar
    Jul 2010
    Kearny NJ 07032
    sunset orange metallic
    2002 T/A convertible
    Hvac control doesn't.....
    My HVAC control recently started "spinning" on the shaft w/out setting any functions...eg: max air, air, defrost, etc. Is it the knob itself that went bad or do I have to pull apart the whole center dash to replace the shaft in the HVAC control? Anybody else ever have this problem? It DOES work the controls but I have to turn the control VEEEEERRRRRYYYYY slowly and feel for the detents at each function. It sometimes is pointing to the floor when it is off. Not Good.
    1st pull the knob off and look on the back side. It should have a flat space kinda like half a circle that the shaft sits on. If this has been rounded out completely then all you should need is a new knob.
    Knobs - junk yards or parts cars
    Next if the knob is still good - try turning the shaft without the knob on. Should be able to turn it by hand but needle nose pliers work also, just don't use a gorilla grip. It should rotate freely form one setting to the other. If it doesn't a new one is needed.
    Dash Unit Controller @ gmpartsdirect = $122.65
    Jul 2010
    Kearny NJ 07032
    I have a feeling that the knob itself is the culprit, the shaft spins ok if I turn the knob real slow. Haven't had a chance to check it, will get to it tomorrow. Thanx
    Jul 2010
    Kearny NJ 07032
    Yes, it was the cheap-ass plastic, made in China, knob. New one: $21.19 from Frank's GMC/ Truck. Problem solved. Thanx for your responses.
  1. Bravada HVAC
    By Z28_Driver in forum Domestics and Foreigns
    Last Post: 12-19-2011, 03:29 PM
  2. Question: T/A Cluster & HVAC Control panel in Camaro
    By fbodyNATION in forum Camaro / SS
    Last Post: 09-19-2011, 02:03 PM
  3. Hvac Blower?
    By camaroluvr447 in forum Camaro / SS
    Last Post: 05-16-2011, 10:52 AM
  4. help with 04 gto hvac
    By laviente in forum General Help
    Last Post: 09-09-2009, 12:25 PM
  5. HVAC digital a/c control
    By 98Roadster6speed in forum Corvette
    Last Post: 12-13-2005, 05:10 AM
