Results 1 to 20 of 29
    my dyno sheet picture...
    Attachment 3849
    this is my 1999 Trans
    LS6 engine SWAP
    slp y pipe and loud mouth cat back exhaust (gutted cats *one took a dump on me*)
    slp air lid w/ K&N air filter...
    other than that i just have the free ram air mod...
    fuggin windows paint!!! can't ever resize something!!! ARGH!!!
    Senior Member FuxOnTheFirstDate's Avatar
    Bumfuckistan
    Shit
    Thats a lot higher than my car, lol.
    Quote Originally Posted by FuxOnTheFirstDate
    hehe... i'm not done with it yet... goan be a while before i get my vortech super charger...
    but in the mean time i gota get my 4:10's installed that are just sitting in my house... but i also gota order an eaton 800 posi unit and stronger axles...
    and headers also...
    Impounded ThackerSS's Avatar
    Palmetto, GA
    00' Camaro SS, 03' z71
    I am sick of hearing about your car. Having an "ls6" is not a big feat. InfacT I submit your car won't trap over 114 or run into the 11's, headers or not.
    You have a weak bottom end, with a shitty heads and cam package, congrats.
    Heres something to shoot for, my car went 11.6 @ 117 with just a cam and headers.. and I have much less money in my car.
    My car now runs a forged 347 built for a 200 shot, and It will be much faster than your car, and I gurantee it has less in the rotating assembly then you have in that "ls6"
    Good numbers for what it is, but don't be surprised when lower HP cars outrun you.
    Just bringing it to you how it really is.
    I'm out there so hide!!!! D!ck's Avatar
    TULSA, OK
    Black & Brilliant Silver
    1999&1997 SL600 6.0 V12's
    Quote Originally Posted by ThackerSS
    why you gotta dis on his car? you can start a thread on your also. just wondering why you attack his car?
    east stroudsburg, pa and middlesex, nj
    2001 Camaro SS M6
    Quote Originally Posted by The Real Spaz
    and headers also...
    nice numbers...i'd rethink the 4.10s though....depending on tire size and shift points..you may run out of gear before you hit the traps. www.f-body.org/gears I'd also check out the ati prochargers...that kit puts out some really nice numbers.
    Palmetto, GA
    Quote Originally Posted by D!ck
    I am not, but for hte past 5 days he has bragged about blowing engines and now he is bragging about sub par numbers from an overpriced engine.
    Canada eh
    99 TA
    This thread isn't about YOUR car... no one gives a fuck if your car is better or faster... he was sharing HIS numbers, so STFU
    Palmetto, GA
    Quote Originally Posted by KyleLs1
    Kyle. Sorry your car is slow, you can be fast too one day.
    However, my point was swapping to an ls6 was dumb if you want to be fast, money much better spent in a heads or cam package that actually makes good power, and bragging about new engines is just dumb. I've never seen anyone go through 5 engines in one year.. the boy really needs to learn to drive.
    look cock sucker face... i was never bragging about blowing up engines... i was posting about my past (bad) experiences with the LS1... witch is why i spent the money to drop in a LS6...
    you either have some sort of jelousy issue's or a really small penis, or more than likely both the way you talk all high and mighty...
    and i haven't gone through 5 engines in a year... it's been 5 engins in a 4 year period...and as for learning to drive... i'm not the best but maybe Evan Smith should take lessons from you since your so damed good... we all worship you...
    Palmetto, GA
    Wait.. you had bad experiences with ls1 so you swapped to an ls6?
    LOL. Real big improvement there.
    Crystal Lake IL
    2001 Camaro Z28 M6
    all of this childish flaming is why I quit posting on this site often....
    I've been a member here for 6+yrs and back before ls1.com had the big crash, it was a great site. Now it just reminds me of a Fast and furious little teenie bopper ghetto import site.
    Real Spaz, sorry for doubting your numbers at first, but 380rwhp was a big claim for a non modded ls6.
    if you want a truely fast car that is reliable, build from the ground up. You have great HP right now so build up your chassis and suspension. If you want to truely grip hard and fast with excellent 60ft times, buy and install these parts:
    LCA,
    PHB
    torque arm
    rearsway bar
    adj. rear shocks
    lowering springs
    and chasis/rearend bumpers
    The idea is get the car low to the ground for limited front to rear chasis travel. You only want about 1.75" at most of chasis travel then the chasis bumpers should hit the rearend bumpers , transfering load energy to the ground making your car launch fast and hard.
    If you want big power, get a cam and set of heads that compliment eachother, along with the rear gear. As stated before if you run a 4.10 you might run out of gear too soon.
    Then if you want huge power go with a turbo setup, yes they are more expensive then a supercharger, but they are more reliable and make more power!
    Is your TA an A4 or M6?
    Crystal Lake IL
    2001 Camaro Z28 M6
    non-modded speaking!
    considering hes at 380, that is a 60+hp improvement over most ls1s, especially 98-00 models which had an ls1 intake, and a less torque cam. Aslo the oil venting in the ls6 burns less oil! which would be nice!
    yes for the price he paid it doesnt seem like much but if the ls1 he pulled was nuked, then yeah a rebuild for oem performance might have cost the same!
    Quote Originally Posted by ibanez7
    LCA,
    PHB
    torque arm
    rearsway bar
    adj. rear shocks
    lowering springs
    thanks ibanez! it's a M6... i've been posting on here for a while also... but on and off... name used to be Spaz but it got deleted with yet again another change... just like it did when ls1 plit and started ls2.com or what ever...
    Dec 2004
    SS: NBM, tan top
    1998-SS, 2010 Jetta TDI
    thackerss way to be an ass hole
    Crystal Lake IL
    2001 Camaro Z28 M6
    lol, i use to post here all the time, but I switched to lsall.com, and of course I have always posted at ls1tech.com (smart group of people)
    M6 excellent thats what I roll with!!!
    have you upgraded your hydraulics yet?
    i have only a ls6 clutch assembly and that is it... toss some info at me!
    "now,you pissed us off!!" Trouble maker's Avatar
    Dyer, Indiana
    Damn....And you guys wanna meet up in Atlanta?They would have to disperse atlanta's entire police force,just to control you guys!
    Dyer, Indiana
    Just kidding!,Can't we all just get along.....?
  1. Finally got the 3rd gen dynoed (Dyno sheet incl)
    Last Post: 09-27-2009, 07:44 PM
  2. Dyno sheet
    By Speed_kills_WS6 in forum Computer & Tuning
    Last Post: 09-08-2009, 02:38 PM
  3. Got my Dyno-Sheet posted!!! and vids of pulls!!
    By ksstamp09 in forum Camaro / SS
    Last Post: 05-05-2009, 06:52 PM
  4. Found my old Dyno Sheet this morning
    By screaminbird in forum Firebird / WS6
    Last Post: 01-31-2009, 08:41 AM
  5. Help me figure this dyno sheet out please
    By Honda Hunter in forum LT1
    Last Post: 09-18-2005, 05:11 PM
