Results 1 to 19 of 19
    Laurel, Maryland
    2000 Grand Prix GTP
    2000 Trans Am WS6 M6
    GTP is going manual
    Since I can't seem to keep the shitty automatic transmissions in the car, I decided to pull the trigger and do the swap. I ended up buying an already assembed "kit" from a guy in Canada. He already had all of the brackets made for the subframe, transmission, pedals, shifter, etc., so this made it easy for me...well, easier.
    Here is a comparison of the two transmissions. The automatic is the one on the cart.
    The weight comparison is hilarious. My friend was able to lift it himself, while him and another friend lifted it above their heads into the car, so I could bolt it in. Who needs a transmission jack when you have friends, right?
    Subframe is out. I supported the engine using a cradle then unbolted the transmission mount, motor mount, steering rack, and control arms. It dropped right out:
    Automatic transmission is out:
    Triple disk clutch rated at 1000hp. I doubt I'll ever reach that, but peace of mind is nice
    Manual transmission bolted up:
    Dash is out to swap out the pedals:
    Shifter is mounted. Had to break out the welder since the bolt holes were not lining up with my car.
    I now need to figure out how to mount the master cylinder and where to drill for the shifter cables to go through to the transmission.
    After that is all said and done, it's off to Frost to get tuned for the lack of automatic. He's going to hate me
    Pittsburgh
    2008 Hummer H3
    Hell ya Muncie 282 with intermediate shaft!
    You won't be disapointed! Those transaxles are known to hold modded ls and sbc power.
    I have a brand new 282 sitting on my bench, just needed an adaptor of converted to a 60* housing.
    You work is/was cut out for you but well worth it imho!
    Keep us posted I am very interested in this..!
    You also now have the f-40 6-spd option as well..
    They make a clutch adaptor and Spec will make you a clutch kit if you don't mind running a spec clutch.
    Coral Springs, Fl
    Sunset Orange Metalic
    You always seem to have something keeping you busy. Amazing how small that tranny is
    Interested to know what it puts down
    Pittsburgh
    2008 Hummer H3
    Oh to add your @ ~ 75-80 lbs with the muncie and over 100 with the 4t60-65..lol
    Pittsburgh
    2008 Hummer H3
    Oops my bad it's a Muncie 284!
    I missed the primary bolt pattern on yours.. The 284 has 11 bolts, and the 282 has 9..
    Congrats on finding the most saught after trans in the w-body/fireo community!
    Looks good J! Can't wait to see the car in a few weeks at Spaz's. I'm digging the pic with the two thumbs up.
    Member Boothe's Avatar
    Apr 2012
    Missouri
    White/Blue
    1999 Trans Am Ws.6
    Wish I had the money for this is my GTP ... would be awesome good job man
    Sent from my Motorola Electrify using Tapatalk 2
    Laurel, Maryland
    2000 Grand Prix GTP
    I was thinking about it, but the 284 was already part of a kit. This way I don't have to fabricate things like the clutch pedal, trans/engine mounts, shifter, etc. Everything is basically bolt-in for me.
    Congrats on finding the most sought after trans in the w-body/fireo community!
    Look in my third pic, the seller gave me his spare 284, just in-case I need it
    Hoping to have it done by then. Just a few more things to work out before I see Frost in a week and a half and Spaz's in two weeks. The thumbs up are my buddy Andre. He was a big help yesterday.
    Another pic you'll appreciate, Jeff. All three of my vehicles in one place:
    Pittsburgh
    2008 Hummer H3
    Damit! 2!?! I missed the second one..lol
    I'm using the 06 G6 3900 GTP shifter, cables, and master..
    I'm lucky as the gen1 W also came in Muncie 5spd so I already have the provision for the clutch peddle and the hole in the fire wall was/is grometed closed (factory) for the clutch rod.
    I have to fab motor/trany mounts though and that's not the most fun..lol
    Looking good so far. Congrats on doing something I thought about a couple times
    subscribed...
    That's a good size shop! You definitely need some more toys to fill that place.
    East of Cleveland, Ohio
    99 WS.6 - Modified
    Im in too!
    Laurel, Maryland
    2000 Grand Prix GTP
    Got a lot done today...clutch pedal in, master cylinder mounted, shifter cables drilled through firewall and attached to transmission, and then all of the interior put back together.
    Ignore the wires on the floor. I have some gauge wiring to do...removing the trans temp gauge since I don't need it anymore, and moving my vac/boost gauge up to my pillar pod.
    Looks like a lot going on with this swap -- you did a whole bunch of work in not a lot of time. You ever sleep? How about a clutch pedal switch with the change over?
    Laurel, Maryland
    2000 Grand Prix GTP
    Sometimes. I'm tired of driving the Suburban everywhere (10mpg sucks), so I'm highly motivated to get this done. Also, I don't want to cancel on Frost a second time.
    I'm not sure what you mean by this.
    Switch installed on the pedal to make sure that the engine will not start with the transmission in gear unless the pedal is depressed.
    Laurel, Maryland
    2000 Grand Prix GTP
    Hmm...didn't think about that. I almost always wiggle the shifter when I go to start the Trans Am.
    I guess I'll just have to be careful. No one else drives the car, so I don't think it will be a major problem causer
    Just a thought. It'd be easy to install one if you ever have to in the future.
  1. Need t56 Manual
    By SMWS6TA in forum General Help
    Last Post: 01-26-2014, 07:05 PM
  2. Manual
    By edrvsqz1980 in forum Firebird / WS6
    Last Post: 07-28-2010, 03:10 PM
  3. Replies: 0
    Last Post: 09-09-2007, 10:12 AM
  4. ATF in Manual......
    By Tyler_LS1 in forum Manual Transmission
    Last Post: 11-15-2006, 12:48 PM
  5. Which is a better manual.......?
    By BatCar in forum General Help
    Last Post: 08-25-2005, 07:44 AM
