07-20-2012, 05:11 AM #1
Hid conversion fog lights 2004gto
I just bought some hipro power fog light the complete kit. It said it was a plug and play kit but after i got it the instructions said if using a single fuse for both lights, the fuse must be at least 15 to 20 amps, but not over 45 amps. So i check my fuse block and the fuse is a 60 amp. But there are two fuses for the headlamps both are 20 amps. I not sure which one it is talking about. The other thing is there are two fog lamp cancel relays as well. Has anyone installed these type of lights? I'm confused any help would be great.
07-21-2012, 01:26 AM #2
The guy I bought them from said to install a relay harness and it has it own fuse, maybe this will help someone else out there.
07-21-2012, 07:06 AM #3
Thanks man, electrical is my weak point!!!!
07-21-2012, 09:29 PM #411 years of bangin gears
- Jan 2009
- North Jersey
Make sure you remove your DRL relay, if you haven't already.
07-21-2012, 11:41 PM #5
Do i need to remove the drl relay for the fog lamps, i'm just installing the fog lamps not the head lights, is this still neccessary?
07-22-2012, 09:03 AM #611 years of bangin gears
- Jan 2009
- North Jersey
My bad. I thought you wanted to install them in the lows as well as the fogs as some of the GTOs I've seen in my area have the HIDs in the lows and fogs. Since you're just doing the fogs, you don't need to pull the DRL relay.
07-22-2012, 09:08 AM #7
Thanks for your input thou.
Tinted Turn Signals, Rear Lights, Bumper Lights
By BADASS2000SS in forum Camaro / SSReplies: 24Last Post: 02-19-2009, 01:10 AM -
2004GTO with NOS VS C6 Z06
By 04REDGOAT in forum GTOReplies: 3Last Post: 08-02-2007, 01:30 PM -
Led Interior Footwell Lights And License Plate Lights
By balog1 in forum Parts For Sale / TradeReplies: 3Last Post: 04-11-2007, 01:22 PM -
By balog1 in forum CorvetteReplies: 0Last Post: 04-11-2007, 06:10 AM -
Conversion to true HID foglight/daytime lights
By cobrahunter in forum Appearance SectionReplies: 30Last Post: 06-19-2006, 08:25 PM
