07-18-2012, 05:13 PM #1
- Jul 2012
- CALIFORNIA
BLACK- 2000 CAMARO Z28
tension tension on my air condition 2000 camaro
ouch ouch ouch my A/C give up. i took it to the mechanic and gave me qoute parts and labor $520 delphi ac condenser, $195 oem hose and $95 acumulator.
P.S still love my z28 2000 camaro.
07-18-2012, 06:26 PM #2
I picked up every piece of a/c used for 150 bucks, and it
's easy to install
07-18-2012, 07:00 PM #3
- Jul 2012
- CALIFORNIA
your right, but i want to keep the car for a long time so im replacing it with new parts.
07-19-2012, 11:56 AM #4
add in a flush, filter and recharge. Ask about those prices
And why he's doing all that make sure he checks the inline filter. If it's not changed it will clog or break and let any metal shavings past it and you'll be right back here.
07-19-2012, 01:45 PM #5
- Jul 2012
- CALIFORNIA
Thank for the info. I feel better now
07-19-2012, 02:29 PM #6
Mines not working I recharged it but not cold what's the deal?
Sent from my Motorola Electrify using Tapatalk 2
07-19-2012, 03:59 PM #7
Are you sure all that is bad? There's a pressure switch, a fuse and a relay for the AC.
Is your compressor engaging? If not, it could be because the fuse is blown, bad relay or the freon is low which causes the pressure switch to not engage the clutch to kick in the AC compressor.
I would check all that before dropping any coin. You can also by-pass the pressure switch to see if the compressor kicks on.Boost gets you laid, unless your name is Jon.
07-19-2012, 06:07 PM #8
- Jul 2012
- CALIFORNIA
Dye make sure nothing is leaking. My a/c is leaking in the middle of the compressor and the hose is rubbing the metal.
07-20-2012, 10:42 AM #9
If the freon level is low, the pressure switch won't engage the AC clutch for the compressor to kick on. This prevents the compressor from burning up. At least this is how I understand it to work.
07-22-2012, 07:26 AM #10
- Apr 2010
- Alabama
If you need AC parts let me know I am removing mine now.
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
07-22-2012, 09:40 AM #11
Best to just buy it new.
Our AC compressor started knocking on the camaro. I bought a new AC Delco compressor (100,000 mile warranty).
When you crack open the AC system it's best to buy a new Accumulator/Dryer. So I bought a new Ac delco piece for that, and I also pulled the Orifice Tube (or filter some call it) because once something goes wrong in the system (namely the compressor) it will pass trash, metal particles throughout the system. That has to be cleaned out or the new compressor won't last long. My compressor knocked for about 30 minutes before I stopped using it and my orifice was already packed full of crap (I have a pic of it, hang on).
As a matter of fact, the GM warranty on the new compressor is only honored if you show that the orifice tube was replaced and the system flushed of debri.
I pulled those lines and flushed them, reinstalled with a new orifice tube (they only cost $1) sucked the system down and recharged. Ice cold and should be good for another 100,000
07-22-2012, 09:47 AM #12
Here is what my orifice tube looked like after 30 minutes of the compressor knocking. I suspect the compressor was probably already passing trash before the knock became audible. In any event, make sure this is changed. They only cost a buck and as you can see, it does it's job to keep garbage out of the accumulator.
tension pulley
By 2-bowties&abird in forum External EngineReplies: 0Last Post: 11-17-2016, 03:39 AM -
Question: tension cable
By tripps in forum ConvertibleReplies: 1Last Post: 05-22-2012, 02:23 AM -
For Sale: 2000 SS Camaro 383 Stroker - Mint Condition
By sscamaro2000 in forum Vehicles For Sale / TradeReplies: 6Last Post: 03-01-2012, 05:53 AM -
2000 GAGT..awesome condition
By claytonr in forum Vehicles For Sale / TradeReplies: 0Last Post: 09-26-2007, 09:38 AM -
belt tension/noise + hypertech programmer question
By AntsSilverC5 in forum CorvetteReplies: 14Last Post: 03-24-2007, 10:31 AM
