Thread: Random Misfire P0300 Help Needed
07-15-2012, 09:09 PM #1Junior Member
- Dec 2010
- Madison, WI
- 1965 GTO
I have an LS1 from a 2000 vette in my Jeep. While out wheeling the other day, it started running really rough and the MIL was blinking. Got it back
to the lodge and wished i had my scanner. Waited a bit, and it started right up and everything worked fine. Went wheeling the next day without any issues.
Had it happen once more on that trip and when we got back ordered and installed a new set of stark plug wires. Just had the same issue tonight. Got it
home, left it running bad and ran for the scanner. Just got the scanner running and it started running just fine. Read a bit on this error code and think it
might be the O2 sensors. I don't have cats, so only the front sensors just below the headers. At this point was thinking I would replace the O2 sensors based
on what I was reading about the random P0300 codes here. I can also do the plugs as that is fairly straight forward. Thinking sensor or electric because it
"comes and go's" so is very inconsistent.
Any thoughts/ideas would be appreciated.
07-16-2012, 05:02 AM #2Your friendly policeman
- Jan 2012
- Alabama
Bright Rally Red- 2001 Chevy Camaro Z28
How many miles on the O2 sensors? Check your plugs and wires and make sure they are all in good shape and properly connected, then go from there.
2001 Chevy Camaro Z28 A4
SLP cold air intake/lid, SLP smooth bellow, Pacesetter LT's, ORY, Magnaflow exhaust, BMR STB, adjustable Panhard rod, SFC's, LCA's, 1LE sway bars, cross-drilled rotors
07-16-2012, 05:37 AM #3Junior Member
- Dec 2010
- Madison, WI
- 1965 GTO
I really don't know how many miles, I picked up the engine from another guy that had it in his Jeep and wrecked it. Since doing the conversion, I have put about 12k on it, and was told it had about 35k when I got it. I did just replaced the plug wires, think I will do the plugs and O2 sensors just in case. Where we go with the Jeep, I really need it to be dependable as it can be a very long walk back if something goes wrong. Thanks.
07-18-2012, 08:04 AM #411 years of bangin gears
- Jan 2009
- North Jersey
Has the engine been tuned to have the second O2s, or lack thereof, deactivated?
07-18-2012, 09:30 AM #5Junior Member
- Dec 2010
- Madison, WI
- 1965 GTO
Yes, i purchased the engine with the computer, harness and program already running. But also had a local tuner help me out here. Also, this problem has just recently started, I have about 12k on the engine since installing it. Bought some plugs and 2 O2 sensors the other day, hope to install them today and see if that resolves this issue. But since it was very intermittent, will be hard to call it "good".
07-18-2012, 09:46 AM #611 years of bangin gears
- Jan 2009
- North Jersey
OK. Keep us posted.
Intermintent P0300 random misfire
By eteller in forum General HelpReplies: 25Last Post: 02-10-2013, 04:39 PM -
P0300 code random misfire...
By MagicMan in forum General HelpReplies: 87Last Post: 07-31-2009, 01:27 PM -
P0300 Random Misfire #2 and #7
By skyking in forum Internal EngineReplies: 8Last Post: 07-10-2007, 09:03 AM -
*HELP* P0300 Multi Misfire
By shwagg in forum Firebird / WS6Replies: 7Last Post: 08-09-2006, 07:51 PM -
Need help with P0300 misfire
By Doc99SS in forum Computer & TuningReplies: 2Last Post: 10-24-2005, 07:05 AM
