Results 1 to 13 of 13
    Junior Member smcdowell722's Avatar
    Jul 2012
    West Islip New York
    BLack
    1998 Pontiac trans am
    7 to 8 codes poped up po131, po300, and quite a few more ..its also cumin up low voltage to bank 1 and 2 o2 sensors I did a fuel pressure test and it running at 30 psi I know its one thing that's,wrong and its causzzing all the other isssues ..help needed thanks
    Junior Member jaydean21849's Avatar
    Jun 2009
    brownwood texas
    1998 ta
    Cats
    Indianapolis
    2000 WS6 6spd Hooker LT
    ^^^what? Converters won't cause low fuel pressure.
    OP, get the fuel pressure problem fixed first, clear codes, and see if any come back. Low O2 voltages = lean, caused by low fuel pressure. 98% chance low pressure caused by bad fuel pump. Multiple misfire caused by low fuel pressure also.
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    I agree on the getting the fuel pressure issue resolved first. How many miles?
    Jul 2012
    West Islip New York
    BLack
    thanks for the help !!!
    The car has 170000 miles borla exhaust and high flow cats what should the fuel pressure be and should I change the fuel filter to see if it'll make the diffrence ...the owner before me did say he replaced the fuel pump already if I do get a fuel pump what should I go with slp intake kn n airfilter headmen long tube headers and higjflow cats h pipe borla exhaust system is all the mods I have done to the car at the moment
    Scott how many miles on the car?
    Any recent mods?
    Never mind we post at same time
    Quote Originally Posted by smcdowell722 View Post
    Fix problem first worry about mods later....
    Go ahead and get a new fuel filter, they are cheap and you will eliminate one of the possible causes to your problem. I change mine every yr. Overkill yes, but better then worrying about it.
    Do you know what the previous owner replace the fuel pump with? Stock vs after market? Did he have a shop do it or himself?
    Did he change the regulator too?
    You can change one or the other separately. Smart guys will do both at same time but if $$ is in a pinch just doing the one that is bad can be done.
    The fuel pressure at idle should read about 45-55 psi. After you do the fuel filter and have no change or problem isn't solved get a fuel pressure gauge and check at the fuel rail on the drivers side. If the pressure reads steady but low it is either the pump or the regulator.
    Now if the pressure drops it most likely is the pick up tube for the pump may have a crack in it. A quick trouble shoot would be if the the tank is full you have no pressure issues however as the fuel level decreases it starts having pressure issues.
    Jul 2012
    West Islip New York
    BLack
    Sry I ment to say those are all the mods the car has right know
    Jul 2012
    West Islip New York
    BLack
    aright
    I do have a fuel pressure gauge its readin 30 psi slowly trims 2 20 psi wen I hit the gas he did it him self once I hanhr the fuel filter this after noon ill check the pump and the pick up he cut a flap uptop to access fuel pump more effectively
    Your friendly policeman FinZ28's Avatar
    Jan 2012
    Alabama
    Bright Rally Red
    2001 Chevy Camaro Z28
    The famous trapdoor. That'll make dealing with the fuel pump easier.
    2001 Chevy Camaro Z28 A4
    SLP cold air intake/lid, SLP smooth bellow, Pacesetter LT's, ORY, Magnaflow exhaust, BMR STB, adjustable Panhard rod, SFC's, LCA's, 1LE sway bars, cross-drilled rotors
    Orlando, FL
    Mean Black
    is the pressure holding when you prime the pump without starting it? or is it dropping? this what you will see if there is a crack in the fuel hose in the pump.
    Leak in fuel pump tube - YouTube
    Indianapolis
    Also be sure the K&N isn't over oiled. That would contaminate the MAF, causing lean problems, but not a low fuel pressure problem. Key On Engine Off fuel pressure should be 58 psi at the fuel rail test port.
  1. Question: 1998 Pontiac Trans Am
    By PurdueMiller5 in forum Firebird / WS6
    Last Post: 06-14-2010, 11:49 AM
  2. For Sale: 1998 Pontiac Trans Am LS1 6 speed trans
    By formula101 in forum Vehicles For Sale / Trade
    Last Post: 10-24-2009, 06:24 PM
  3. For Sale: 1998 Pontiac Trans am
    By joels1bird in forum Vehicles For Sale / Trade
    Last Post: 06-19-2009, 09:56 AM
  4. For Sale: 1998 pontiac trans am
    By ls1bitches in forum Vehicles For Sale / Trade
    Last Post: 09-18-2008, 07:40 AM
