Results 1 to 20 of 22
Thread: Resetting OBDII
07-01-2012, 05:35 PM #1Member
- Jun 2012
- florida
Resetting OBDII
02' transam, if the battery is disconnected for some time will the codes be cleared?
07-01-2012, 05:50 PM #2
yes some of them. If the code comes back it will light up right away. Which code is it?
07-01-2012, 08:44 PM #3
In my case when i switch from my DS Predator Performance tune back to the stock tune (for emissions test)or visa versa The obdII will reset the emissions monitors. Some are continious some non-continious monitors.Ive never had a it throw any codes though. There is a specific driving pattern per make and model to reset them found on the net @ GM related sites. I have a hand held device that plugs into the obd port that tells me which monitors are set or not. As long as your not going in for an emissions teat you should be ok and the monitors will reset themselves in time.
07-01-2012, 08:51 PM #4
OOPPs! Sorry guys i didnt read your question right... Oh so i guess your throwing codes now and want to know if disconnecting the battery will clear them?...Yes it will but depending on the codes they may just pop back up again. I had one pop back after only 12 miles of driving.arggghh!!Like JayTA98 says. To me its best to invest in a code reader and try to correct the problem if possible This way youll always have a reliable way of reading and erasing trouble codes, I bought one for 57 dollars.
07-01-2012, 08:53 PM #5Former Mopar Man
- Jun 2011
- Branchville, NJ
Post your codes.
07-02-2012, 04:15 AM #6Member
- Jun 2012
- florida
codes
171 & 174, lean banks 1 & 2. I cleaned the MAF and tried to find the PCV to see if its leaking around the connection but I think its missing. I was told it should be near the front of the engine.
07-02-2012, 05:22 AM #7Magnaflow Quad Tip, Lid, SBellow
UMI: FTC, FSB, RSB, LCA's, PBAR, SFC's, T-Arm w/relo, D/S Loop
Kooks LTH, 3" YP, H/F Cats
Custom Grind Cam, Stall, 3:73 rear
Bilsteins w/Strano Springs Conti Super Contacts
TuneByFrost MSD Wires
Cross Drilled/Slotted Rotors w/Ceramic
07-02-2012, 05:37 AM #8
Is this your vehicle? It sure looks like is missing the valve but in an 2002 the PCV valve tubing is different. Is more like an U shaped and it goes down to the valley cover right underneath in that pic. Is the car completely stock? That setup looks more from the 98-99 were the valve is further back inline.
07-02-2012, 05:41 AM #9
07-02-2012, 05:52 AM #10Former Mopar Man
- Jun 2011
- Branchville, NJ
A 2002 Trans Am should have the PCV system right up front near the passenger valve cover.
07-02-2012, 06:10 AM #11Junior Member
- Jun 2012
- hamilton
red- 2000 ta ws6
how long do you keep the battery disconnected to clear the codes.
07-02-2012, 06:11 AM #12
I have to agree with you on this one. I'm thinking of the U shaped hose but that's only when the LS6 valley cover has been equipped. The PCV valve should be right were that strap is. Did you check that tube all the way back? Is it a straight piece of tube all the way back? If it is then yes it has been deleted.
07-02-2012, 06:13 AM #13
07-02-2012, 06:15 AM #14Junior Member
- Jun 2012
- hamilton
red- 2000 ta ws6
disconnected both cables?
07-02-2012, 07:16 AM #15
i only disconnect the negative
07-02-2012, 07:22 AM #16Member
- Jun 2012
- florida
PCV
The hose is straight and goes all the way back. I do see some metal elbows on the front of the covers but they are not PCV valves, just elbows for hose connections. I checked the rear 2 hose connections (nice and easy to get at NOT!!) and they look ok, no pcv. What would happen if you ran a car without one?
07-02-2012, 07:08 PM #17Senior Member
- Apr 2010
- Alabama
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
07-03-2012, 02:04 PM #18
I bought (online) a * AutoLink (AL309) Professional obd-II code reader/scan tool for around $ 57.00 bucks! They do have one thats a little more advanced,that i wanted after but for what i needed it for and price its great! (so do your research for the one you want) Autel.us | Car & Vehicle Diagnostic equipment | Engine ODB Software | MaxiDas DS780 or Amazon search. or I have a DiabloSport Predator hand-held tuner/scan tool also. Although it has many power adders etc it cannot show emissions monitors!
07-03-2012, 02:12 PM #19
07-03-2012, 03:49 PM #20
Resetting ABS light w/o trac
By Whamhammer in forum General HelpReplies: 0Last Post: 04-07-2015, 04:56 PM -
Resetting OBDII
By johnfin in forum Firebird / WS6Replies: 0Last Post: 09-05-2012, 05:20 AM -
Resetting the Security Light
By whiteflash in forum Stereo and ElectronicsReplies: 0Last Post: 03-19-2007, 11:08 AM -
Resetting the cars computer
By Sarge in forum General HelpReplies: 35Last Post: 05-04-2006, 09:23 PM -
Resetting PCM
By wc00ac in forum LT1Replies: 3Last Post: 08-30-2005, 10:31 AM
