Results 1 to 20 of 22
    Jun 2012
    poconos pa
    red, yellow
    88 rx5.7 69 chevelle SS
    build 1 my 88 mazda rx7 ls1 swap
    here is the story my rx7 has been with me for a very long time! i love this car for some reason! i just cant seem to give it up! I had a 13b NA in it and i said well i want more power so i swapped in a 13b turbo
    so after blowing yet another seal i got sick of the motor and i was going to sell the car off. then a buddy told me put a v8 in it and call it a day. I thought he was crazy but then i started searching and sure enough people started swapping v8s in them! so i picked up an LT1 from a junk yard
    after the machine shop got it it was bored out 30 over.
    new pistons
    all together well the short block
    now don't laugh but at the time all i had was this bright blue paint..lol
    all together
    intake after a nice hot tanking and paint
    flywheel resurfaced
    all together now
    Jun 2012
    poconos pa
    red, yellow
    mount kit installed
    motor fit in pretty good and i was shocked to see the shifter in the stock location
    after a few more weeks i finally got it running
    then i bought a house and had some time and space to work on the car
    now don't laugh to hard at my wife no clue why she thought the camera was not picking up audio!
    lol
    yes those are mustang wheels
    i had some issue with it and it was electrical! and boy did it bother me but i finally got it working again man i miss having a cammed motor..lol
    and my first time auto crossing
    then i started having electrical issues again and i ended up like this
    Jun 2012
    poconos pa
    red, yellow
    yup you guessed it opti spark again! then i said ok thats it i am tired of this time to get an lq4. so i got my LQ4 home and then a buddy came over and said to me "hey what are you doing with that motor?" told him its going in the 7 and then i he told me something i will never forget! "lets trade block for block" you cant even imagine the smile i had on my face i was like hell yeah!
    so i got it home and this is what i had!
    inside the vally
    inside the valve cover
    with the ls1 intake back on it!
    ported ls1 TB (thanks jamie)
    fuel rails and lq4 turck coils on it
    maf and water pump bolted on
    ls1 flywheel bolted on with arp flywheel bolts and apr pressure plate bolts
    the things not on yet!
    f body crank pulley, because i don't have a puller for it yet
    f body altenator, because i don't have the mounting bolts yet
    and the wiring harness and pcm in the box not ready to start modding it yet..lol
    Jun 2012
    poconos pa
    red, yellow
    got the wiring harness as much together and apart as i could in the bay
    headers are unbolted
    oil pan, tray, pick up, and dip stick all came in the mail
    as to much suprise i had another knock on the door today and it was my race proven racing baffle with trap does on it!
    so i said let me clean the oil pan up and get the new baffle in it
    before
    after
    Jun 2012
    poconos pa
    red, yellow
    sitting in the working out room
    radiator sitting in the background
    half way out
    out just need help steering it out
    out and trans is off
    the motor is ready for the new owner
    playing with the slave cylinder to make sure that i can use my setup
    i took the stock quick release from gm so i can use my SS line from the lt1
    happy to see that it fits well and i am going to buy a new fitting so is 180 not 90 degrees
    thats all i can do for now until i get some parts solds so i can buy more parts to finish off the swap!
    Jun 2012
    poconos pa
    red, yellow
    some stuff came in the mail today
    my long tube headers!
    and my t56 for the ls1 is here!
    Jun 2012
    poconos pa
    red, yellow
    how to convert the ls1 slave cylinder
    rusell fitting
    out the box
    aparts
    with the new fitting installed
    stock bleeder with the remote bleeder
    all together
    on the t56
    on the face plate
    Jun 2012
    poconos pa
    red, yellow
    some more stuff showed up in the mail
    i got new mounts too because i noticed my old ones looked like this
    and for 8.44 i got two new ones
    Jun 2012
    poconos pa
    red, yellow
    i finally got off my butt and did some work tonight!
    clutch installed, bellhousing on, new f body oil pan with race baffle installed.
    i had to sneak away from the wife and take the 25 mins to get it together!
    Hi i am Shaun and i approve this swap!
    now get in the car mister!
    now i am waiting for my power steering rack to come in the mail get that all together and drop the motor in over thanksgiving break! (i hope!)
    o and some where lucky enough to see the happy fat man dance! because i got it done so quick with out the wife noticing i was gone (it was my turn to change the baby and give her a bath and i just turned into a vapor...lol)
    Jun 2012
    poconos pa
    red, yellow
    finally she is in and bolted it on her own power!!
    - - - Updated - - -
    pure sexiness!
    Jun 2012
    poconos pa
    red, yellow
    Some stuff done today!
    ran my fuel lines today! and put in my vette fuel filter and ran the lines the way it needs to be. I ran it the same way Granny shows on the website
    ran the line from the master cylinder to the slave cylinder
    and installed the oil pressure sensor
    things not pictured the water temp sensor is in
    I think all that is left for me to do is the headers, get the lines from the heater core to the water pump. mine are to short so i am going to route that this week!
    ran the hose for the PCV,
    if you guys can think of anything i need to do please let me know. if not i think i am almost done. all i need is headers done, a small pipe from the headers to the exhaust, O2 sensors, starter bolts and bolt the starter to the block. wiring and ready to go!
    greg doing what he does best! wiring
    then busting a groove on the welder!
    but getting welds like this!
    Chris finally getting off his ass and doing some work!
    he did a great job on my gauge cluster! The stock rx7 cluster is a cable speedo so we took an integra speedo and wired it up to the VSS and its almost perfect! when it should of been 60mph it was reading 57 i can live with that much better then having nothing or having one that says 45 and doing 63 like my old one was!
    Jun 2012
    poconos pa
    red, yellow
    grinding down some of the welds from the tack fittings
    ANGERED!!
    but they turned out good!
    passenger side ! DUMB easy to do!
    driver side OMG what a pain!
    Jun 2012
    poconos pa
    red, yellow
    greg had to put all 125 pounds on it to get it in place! LOL
    still not there yet!
    you can't see the hammer but i am beating the hell out of the firewall for about 1 inch of room for the header to get in there!
    finally got it to line up right!
    now i have to figure out what i am going to do with the pcm
    finishing touches before we start it up
    and finally this!!
    Jun 2012
    poconos pa
    red, yellow
    finally off jack stands and moving under is own power!!
    well i worked on it some today. i spent yesterday and today trying to find some intake piping so i can make a nice cold air intake but i couldn't find anything that was 3.5, since my MAF is 3.5 i figured i would be able to find something man was i wrong. A & A had only ricer intakes that where2.5 or 3 inches but no step downs so i could at least put the 3inch intake on. So i ended up going to home depot and went to the PCV section and i fould a 3 to 3 but when i messured the inside of it, it came back 3.5 on one side and 3 on the other side. so i took it home and used all my old LT1 stuff and came up with this
    what do you guys think?
    i am proud of myself! i actually sat there with a wiring diagram and found the illumination wire so when i flip the headlights on the gauge turns on
    now all that is left is to put the rest of my interior back together mount the pcm,wheel alignment and exhaust. I should have my interior back together this week I hope
    i got her back on all fours and started getting things together. i have so many small things to work on. but here is what i did today
    don't mind the open master cylinder i was about to bleed it but my garage is such a mess i couldn't find my bleeder..lol enjoy!
    Jun 2012
    poconos pa
    red, yellow
    and then i took it to the dyno just to see how she would do untuned and man she put down more power then my cammed lt1
    hope you enjoy it! i have a lot of work left to do but she is up and running and will stay this way until my chevelle is ready for the road
    Impressive
    very nice.......you should make a poster out of all those pics to hang in your garage.
    Nov 2009
    Jacksonville FL
    TRIPLE BLACK
    2000 CAMARO SS M6 #2100
    nice job man
    Your friendly policeman FinZ28's Avatar
    Jan 2012
    Alabama
    Bright Rally Red
    2001 Chevy Camaro Z28
    Very nice.
    2001 Chevy Camaro Z28 A4
    SLP cold air intake/lid, SLP smooth bellow, Pacesetter LT's, ORY, Magnaflow exhaust, BMR STB, adjustable Panhard rod, SFC's, LCA's, 1LE sway bars, cross-drilled rotors
    Jun 2012
    poconos pa
    red, yellow
    lol i like the idea of the pictures but i have over 300 pictures of my builds...lol hell right now in my chevelle build i have almost 300 pictures and i haven't even touched my lq4 yet..lol
  1. HOTRODREGAL.COM is my LS 6.0L build/swap
    By AV8 in forum LSx Retrofit and Swap
    Last Post: 02-10-2018, 02:05 PM
  2. Question: Lt build or ls swap
    By Wes97ta in forum Internal Engine
    Last Post: 10-11-2011, 04:45 PM
  3. LS6 SWAP and build with pics
    By redbird555 in forum Internal Engine
    Last Post: 05-31-2011, 03:31 AM
  4. For Sale: FS/FT 1993 mazda rx7 with LS1 swap need to sell ASAP!!
    By inspector gadget in forum Vehicles For Sale / Trade
    Last Post: 11-19-2010, 06:35 PM
  5. LS1 swap or build up LT1
    By darkass300 in forum General Help
    Last Post: 05-07-2006, 08:55 AM
