Results 1 to 13 of 13
    Member screamin chicken's Avatar
    sc
    Black, Red, Silver Jade
    00 WS6,95 Ta, 69 R code
    computer help.....
    I cannot get my email to open, and my lan is disconnected, need help please....
    WI
    Blog Entries
    1
    09 EclipseGT 75 Chevy 4x4
    2001 Trans-Am 13 F-XT
    And you need help with...?
    YOW Pookie's gone postal! Motrv8d Steve's Avatar
    North San Diego Co.
    1998 Camaro Z28
    This happens to me occassionally at home and here's what I do to fix it. Geeks, correct me if I'm wrong, but I've had tech support walk me thru this procedure before:
    Turn off your 'puter. Unplug your modem (or turn it off if there's a power switch) and wait for 20-30 sec. Then turn it back on (plug it in). If you have a router connected to the modem, then unplug the router after you unplug the modem and then reconnect the router second after the modem comes back on when all the lights that are supposed to be green are green.
    Then turn on your 'puter again. Should be good to go. This is what's called resetting your modem and I have to do it every once in a while.
    Hope this helps.
    Leaving for Lackland soon
    Bismarck, ND
    2000 Z28 M6
    sounds right, providing that is is issue, there wasnt much information givin on the situation.
    2000 Black Camaro Z28 - !Cags, Spec Stage 3 clutch, Drill Mod, Smooth Bellows, High Flow Lid, Free Ram Air Mod, 150 Wet Shot Cold Fusion Nitrous
    N/A 333rwhp 340 RWTQ
    N20 476RWHP 493RWT (Finally got it tuned)
    http://www.dakotafbodies.com
    North San Diego Co.
    1998 Camaro Z28
    so what IS the sitchy-ashun?
    did it work?
    Are you there?
    hello helllloooo, testing testing wherethefuckareyou?
    sc
    ok thanks, tried it 3 times and still no luck heres what it says
    A time-out occurred while communicating with the server. Account: 'mail.charter.net', Server: 'mail.charter.net', Protocol: POP3, Port: 110, Secure(SSL): No, Error Number: 0x800CCC19
    2007 Yukon XL (sold)
    2014 Z71 LTZ 3LZ (sold)
    2010 Escalade Platinum AWD , 6.2
    2017 Silverado HC , 4x4, 6.2
    2000 WS6 ASC#2300 Holly LS6 intake, TR Custom grind cam, Mac Mids w/ ORY,Hotchkis LCA's, PHB, BMR Extreme STB, BMR re-location brackets,Eibach Sportlines, GMMG, Mccleod Pro 5.0, SLP SFC's, OEM ZO6 wheels
    1995 TA
    1969 R code Mach I my new project
    Member Tman's Avatar
    Woodstock, GA
    2000 WS6
    Have you contacted your ISP (Comcast)? Perhaps they are having problems with the mail server.
    Are you able to access the internet at all ? or is it strictly your email?
    sc
    email is the only problem, thanks from another scfyb member.....lol
    Space Cadet RainMan's Avatar
    Port St. John, FL
    Red & Dk Gray
    2002 WS6, '08 G8 GT
    North San Diego Co.
    1998 Camaro Z28
    this is beyond my scope now.
    good luck with your problem
    sc
    Thanks for the links and time Rainman, I will download and let you know...
    Member tnthub's Avatar
    Brunswick, Maine
    1994 Camaro Z28
    If you are timing out, then that is what is happening. Too much time and you lose your connection.
    There is not enough detail to know where the problem is, except that if your lan is not connecting youwon't be able to see other computers on the network or get online. if that is the case try running a repair on your network connection. If you have XP you should be able to right click on network connection, properties, local area connection, and then click repair. If it is something simple/stupid, it may just start working.
    You may also want to do a full virus sweep, spyware sweep, and check the hard drive for errors. Clean out your temp files from your internet folder, defrag, and when you get reconnected check for updates from MS and your anti-virus and spyware vendors.
    2002 Street ET Champion New England Dragway
    1999 Street ET Champion Oxford Dragway
    My Blog is here: http://www.downtime.com
    sc
    ok thanks....
  1. Question: truck computer versus car computer
    By BBCCarguy in forum Computer & Tuning
    Last Post: 11-03-2011, 08:47 AM
  2. In car computer?
    By pbguy357 in forum Stereo and Electronics
    Last Post: 09-23-2010, 07:53 AM
  3. Computer help please
    By screamin chicken in forum Almost Anything Goes
    Last Post: 11-06-2007, 05:12 PM
  4. Replies: 10
    Last Post: 10-29-2007, 03:50 AM
  5. computer help
    By kosovobandit in forum Computer & Tuning
    Last Post: 09-24-2006, 06:59 PM
