Thread: 2004 GTO - Muffler Delete
06-20-2012, 06:29 PM #1Former Mopar Man
- Jun 2011
- Branchville, NJ
I have a 2004 GTO which is mostly stock and it has 50k on the clock. I am getting ready to do some mods and I was going to start with the exhaust. I was thinking about going with the stock system for now but going muffler delete and running just the cats and resonators. Has anyone done this before and how does it sound. Will I throw any codes. I plan on using 2 1/4" pipe bent at my local muffler shop. Any advice would be welcome.
06-23-2012, 12:26 PM #211 years of bangin gears
- Jan 2009
- North Jersey
If you have a muffler on either side(SAP), you can just get the, I think, Kooks axleback pipes. They bolt where the
mufflers go and they are 2 1/2 inches in diameter so you don't lose exhaust flow. I have heard 05/6 GTOs with the
muff delete and they sound really nice. You won't get any codes. Check our sponsors as I believe they have the
pipes you need. By the way, they come with tips already welded on.Last edited by cammed goat; 06-23-2012 at 12:31 PM.
06-23-2012, 12:44 PM #311 years of bangin gears
- Jan 2009
- North Jersey
If you have the two pipes out the driver side, just weld in some pipes where the mufflers were.
06-23-2012, 01:18 PM #4
I did the muff delete a few years back, it will be loud and pop a lot when you let off, with the rest of the exhaust on cabin noise won't change much if at all. I like loud and ran it that way for 2 years.
06-29-2012, 01:44 PM #5
If you remove the panel behind the right rear wheel you will find a threaded hole to allow to hang a dual exhaust exiting both the left and right sides. I had to get rid of BMW look. PFYC sells a template with sleeves. You scribe with a marker on the lower right rear portion of valance. Cut outside/inside the line depending on how you look at it, meaning you can always trim, but you can't put material back. You dremel both sides, epoxy in the sleeves and paint... Buy the sharpest wheel dermel sells and run at the highest rpm and let the wheel cut without generating heat. In other words don't force the through the plastic. This avoids the clumpy crap that builds up when cutting plastic. Key is taking your time.
160 tstat
K & N CIA
Diablo custom tune
Borla dual exhaust
CAGS Eliminated
Catch Can / Breather Filter
TB Bypass
06-29-2012, 04:11 PM #6Former Mopar Man
- Jun 2011
- Branchville, NJ
06-30-2012, 10:45 AM #7Member
- Mississippi
Impulse Blue- 2004 GTO
Are you after sound or performance? Just leave the cat back if you are doing doing headers. The stock cat back flows surprisingly well and has a great tone. I only lost a handful of rwhp going from a Corsa Touring back to the stock cat back and that was when I was making around 430rwhp.
Rob
04 GTO
96 WS6
muffler delete, bad decision
By dennis ss in forum External EngineReplies: 11Last Post: 07-30-2010, 11:28 AM -
Question: Has anyone done a Muffler delete?
By TheJudge05 in forum GTOReplies: 12Last Post: 05-28-2010, 10:49 AM -
Delete Muffler or keep.
By karpetcm in forum External EngineReplies: 3Last Post: 03-24-2010, 01:15 PM -
Muffler Delete
By srleadguitar in forum External EngineReplies: 8Last Post: 10-12-2009, 01:08 PM -
muffler delete.....
By 0rion in forum GTOReplies: 1Last Post: 02-18-2008, 07:54 AM
