Thread: Front Rim Size?
06-11-2012, 09:17 PM #1
Front Rim Size?
Whats the biggest/best size rim to run on the front?
06-12-2012, 11:42 AM #2
What do you mean by "best"? What are your plans for the car? Autocross? Drag racing? Show?
I like 17 inch rims cause it still has room for enough sidewall but a 275 is probably as wide as you can get safely and probably a 40 on height. Some people run 18's/19's and 20's too
it depends what you want to use the car for.
06-15-2012, 06:16 PM #3Junior Member
- Jun 2011
- st. marys,md
black- 2000 trans am
i run 17x9 in front
06-18-2012, 11:07 AM #4
06-18-2012, 11:12 AM #5
To be able to rotate then you could run a 275 that would be perfect, anything biggger would probably be to big for the front. A 9inch wide is probably the widest you could run up front.
06-18-2012, 05:07 PM #6Senior Member
- Feb 2010
- Greenwood, IN
Light Pewter Metallic- 2001 Camaro SS
I am running 18x10 and 18x11 in the rear. If you really want to go wider in the rear its going to be difficult to run the same size up front. I am running 275s up front and 315s in the rear.
2012 Regal GS
2004 Cadillac CTS-V (Sold)
2001 Camaro SS (Sold)
1999 Camaro Z28 (Sold)
06-18-2012, 06:17 PM #7REAPER Z28
- Apr 2009
- Tyler TX
Navy Blue Metallic/Black- 02 camaro z28/01 wife t/a
i run 17x9.5 up front, but i seen some people run 17x10.5 with out a prob as well
06-20-2012, 09:57 AM #8
i ran a 285 40 17 tire up front with no problems. Stock suspension though.
06-20-2012, 05:19 PM #9
Been as wide as 265/45 Auto-x on the front..
That was plenty wide. I agree with the others on wider out back and not so much on the front.
size or rims for front and back
By shadowbandit in forum Wheels and TiresReplies: 0Last Post: 03-02-2011, 01:40 AM -
Question: Front Sway Bar End link size?
By KCC455 in forum Suspension and HandlingReplies: 11Last Post: 04-21-2009, 07:43 PM -
What size up front
By M-Ten in forum Wheels and TiresReplies: 6Last Post: 02-20-2008, 10:46 PM -
What size Tires on the front of my Camaro??
By daniel24ss in forum Wheels and TiresReplies: 11Last Post: 08-09-2007, 10:15 PM -
What size tires on the front??
By daniel24ss in forum Camaro / SSReplies: 2Last Post: 07-28-2007, 10:04 AM
