Results 1 to 14 of 14
Thread: Sway bar endlinks for an 02 Z28
06-04-2012, 01:39 PM #1
Alright guys, I just swapped out the stock shocks off of my dad's 02 Z28. While I was there I noticed that the endlinks need to be replaced. They are the still the stock one's and they are showing their age with the car having 90K miles on it. I will be doing both the front and rear. This is his daily driver so I am just looking for stock replacements. I am going to go with Moogs but I see there are a few available. I would like to be sure that I get the correct ones. I am also going to swap out the bushings for both front and rear with Moogs as well. Those I know which to go with.
These are the endlinks that are listed. I need to know which is the correct stock replacement.
It looks as though K5252 and K6217 are rubber and K6630 and K6678 are thermoplastic. It also appears that I can go with K6630 all around. I will probably upgrade to the thermoplastic style.
Thanks for the help.
Part Number: K6630
Description: Front; Problem Solver; Heavy Duty Design
Part Number: K5252
Description: Front; Standard Design
Part Number: K6678
Description: Rear; w/H/D Susp.; Problem Solver; thermoplastic rubber provides additional performance and handling benefits
Part Number: K6217
Description: Rear; w/H/D Susp.; Standard Design
K6630 and K5252 are also listed for the rears.
Part Number: K6630
Description: Rear; w/Std. Duty Susp.; Problem Solver; Heavy Duty Design
Part Number: K5252
Description: Rear; w/Std. Duty Susp.; Standard Design
2002 Artic White SS 35th Wheels|Full Hotchkis Suspension|Koni SA|Magnaflow CME|SLP lid|www.fquick.com/The_Guz
06-04-2012, 01:55 PM #2
- Apr 2012
- fort myers florida
I honestly bought the energy suspension kit from autozone. It was 21 dollars and the Moog is a few cheaper. I love the way I handled after the energy suspension kit
Sent from my DROID BIONIC using Tapatalk 2
06-04-2012, 09:37 PM #3
Moog HD units are all you need..
I've used them myself on everything for more than 15 years now.
Including my 01 Camaro.
06-04-2012, 09:41 PM #4
Oh yeah I no longer have the part number. But they used the blue bushings.
06-05-2012, 05:44 AM #5
- Jun 2011
- Branchville, NJ
Let me know how the Moogs work out. I'm due for new end links.
06-05-2012, 06:04 AM #6
- Jan 2012
- Alabama
Bright Rally Red- 2001 Chevy Camaro Z28
Since we're discussing it, I have 1LE endlinks front and back (they were already on the car when I bought it, leading me to believe the sway bars are 1LE, also). Can I switch to a different endlink or should I stick with the 1LE stuff? Reason I ask is because back years ago, on another board and with a different Camaro, there was some heated discussion about how you couldn't use anything other than 1LE endlinks with 1LE sway bars.
2001 Chevy Camaro Z28 A4
SLP cold air intake/lid, SLP smooth bellow, Pacesetter LT's, ORY, Magnaflow exhaust, BMR STB, adjustable Panhard rod, SFC's, LCA's, 1LE sway bars, cross-drilled rotors
06-05-2012, 06:06 AM #7
- Mar 2007
- Henryetta/Tulsa Oklahoma
Jacked mine up a few weeks ago, my passenger endlink was GONE. Bought Moog HD's, not expensive and I've heard good things. Hell anything is better than literally nothing still scratching my head about that though ...
Sent using my telèfono
06-05-2012, 12:40 PM #8
Thanks for the responses. I'll just go with the HD's.
06-05-2012, 03:48 PM #9
06-05-2012, 05:14 PM #10
06-05-2012, 08:27 PM #11
06-06-2012, 04:35 AM #12
06-07-2012, 12:50 PM #13
I switched over to non street legal super sticky auto-x tires and broke ALL 4 of the stock endlinks on my 01 Camaro.
Now it was a 3800 car, but the two cars have only minor differences in weight if any..
A dressed 3800 weighs a few Lbs. off that of the LS1 engine.
With that said,, I changed out to moog hd links as I had used their products (bar links and bushings),
on many of my past vehicles, cars and trucks alike..
Super simple to change out..
06-07-2012, 12:54 PM #14
Almost forgot,, I never broke a MOOG link either... and I jump my trucks..
Replacing endlinks, bolts stuck
By thephalanx in forum Suspension and HandlingReplies: 4Last Post: 06-24-2009, 03:39 AM -
MAf,AGX rear shocks, Strano sway bars,1LE sway bar
By AFASTYZFR1 in forum Parts For Sale / TradeReplies: 3Last Post: 09-21-2008, 01:54 PM -
Z06 endlinks
By BlownC5 in forum CorvetteReplies: 1Last Post: 08-29-2006, 04:47 AM -
19mm rear sway bar with endlinks and bushings for sale
By Hurley711 in forum Parts For Sale / TradeReplies: 0Last Post: 02-10-2006, 06:11 PM -
1LE Swaybar w/ Poly bushings & Endlinks
By Joe K. 99 Zeee!! in forum Parts ReviewReplies: 3Last Post: 12-20-2005, 10:12 AM
