Results 1 to 11 of 11
    Junior Member nathanWS6's Avatar
    Jan 2012
    spring hill,FL
    2000 trans am ws6
    epoxy throttle body mod
    does anyone have any experience with doing the epoxy mod on the throttle body? some say it's dangerous and not worth the benefit.
    guys online are selling this option with the port and polish. any input would be great.
    thanks
    Epoxy IMHO not worth it.
    A good P&P TB will give you very minimal gains but not enough to say yeah that is what gave a 1/10th of my time.
    P&P just removes extra material, giving it a slightly better flow over a stock TB.
    I can see were using an epoxy could make it smoother but not so much that if the material comes off because of shitty application or the product that is use, is it worth a blown motor.
    If more flow volume is needed/wanted step up to a NW or FAST 102 TB's.
    Jan 2012
    spring hill,FL
    2000 trans am ws6
    it actually is to fill in the notch where the vaccum lines are and is then re-drilled so there is just 2 holes instead of a big notch in the throttle body throat
    here's the link and you can see it in the picks
    Ported & Polished LS1 Throttle Body TB 5.3 6.0 | eBay
    I see, what I read up on was totally different then the link you posted.
    I'm a little skeptic on the HP numbers claimed.
    Jan 2012
    spring hill,FL
    2000 trans am ws6
    you can see it though.. looks like a good idea but, like you said skeptical on the numbers or if in would hold and not come loose
    Member JacobLS1's Avatar
    Feb 2011
    Colorado
    1998 Z28
    It might be better to just upgrade the tb like posted above. I have a P&P, epoxied TB. If you're not careful you could take too much material away, like the previous owner did, and run into idle/running problems. The epoxy wasn't an issue, it does make sort of a whistle, nothing high pitched but noticeable.
    If you do it, just take your time and do it right. Throttle bodies aren't too cheap, let alone an engine rebuild.
    more goes into a p&p than just the epoxy part of it. I would say if you're confident you can do it and use a good epoxy then go for it. Knife edge the blade and shave the back of the shaft while you're in there. Just make sure not to over port the blade area or you'll have idle issues.
    Pittsburgh
    2008 Hummer H3
    If you damage the ventury landing area the engine may not even run.
    The ventury is the blade, or (butterfly) it depends on it's bore being precise.
    Do not change the angle on the top and bottom of the blade,
    as this should have a 0.0 tollerance when properly centered/closed in the ventury bore.
    Personally I would mill it rather than P&P..
    Just my .02
    Pittsburgh
    2008 Hummer H3
    Here's a TB I built a while back.
    Only a touchup hone on the Ventury bore to true it up.
    The rest was milled and polished.
    Waiting on the Tree transamtom's Avatar
    Niagara Falls Ont.Canada
    1999 TA A4
    I got mine from Photz on ebay,he does good work.
    Member SuperSSguy's Avatar
    Jul 2012
    NorCal
    Sunset Orange Metallic
    2002 Camaro SS M6
    Yeah this is an old thread BUT....... Has any members had any more to add?...Im thinking of getting a P&P TB job with or w/o,epoxying from that potz guy from e-bay Anyone have any other suggestions on where to get it done? There was another name of TB sellers or P&P`ers on this site but cant remember name?I dont think im into getting(paying for) a larger TB right now but im getting a proper tune done and want to stick with what i have (a stock TB) for now and i wanted to get the P&P done before the tune???? anyone..........
  1. Question: used ls6 throttle body
    By CHEVY211 in forum External Engine
    Last Post: 01-25-2012, 06:24 PM
  2. Question: throttle body
    By reaper ws6 in forum External Engine
    Last Post: 05-12-2011, 06:56 AM
  3. 01 throttle body
    By Scott5586 in forum Parts For Sale / Trade
    Last Post: 10-15-2007, 05:36 PM
  4. throttle body
    By 99-SS-Conv in forum General Help
    Last Post: 01-29-2007, 08:52 AM
  5. 98-02 stock LS1 f-body throttle body
    By noblesramair in forum Parts Wanted / Trade
    Last Post: 03-04-2006, 05:59 PM
