Thread: diesel guys.....
05-28-2012, 07:08 PM #1
diesel guys.....
Any of you guys good with diesels? My buddy has an 06 duramax vin 2 and last year he started throwing the 0087 code for low rail pressure when towing. It pretty much only does it when it's hot out and he's towing his camper. We replaced the rubber section of the fuel line coming from the tank. It was soft as hell and my money would've been that replacing that would fix it. He threw it again this weekend towing the camper. We're taking the trailers to VA Beach in 2 weeks and I'd really like to get his truck squared away before we go. I'm just not sure where to start or how to even properly trouble shoot it. I don't want him throwing parts at it if we can help it because the CP3 is expensive and doing a lift pump is expensive. I've also read it may be the fuel pressure return valve but not sure how to test it.
05-28-2012, 08:57 PM #2Member
- Apr 2012
- fort myers florida
Did you do a fuel filter?
Sent from my DROID BIONIC using Tapatalk 2
05-28-2012, 11:23 PM #3
yeah.....this has been going on for over a year now so he's done a couple of filters. I'm going to have him bottle test the fprv this week and see if his release valve is leaking and needs shimmed or replaced. I'm pretty sure I can look at injector balance rates with efilive so I'll look at those for him next weekend to see what his injectors are doing. I hope it isn't that or the cp3.....expensive shit.
05-29-2012, 02:16 AM #4Junior Member
- May 2012
- Pakistan
yeah its not a expensive shit but you first try more fuel filters
05-30-2012, 02:33 AM #5
It could be a leaking injector.
Sent from my DROID BIONIC using Tapatalk 22002 WS6 TA VERT M6 HOOKER SUPER COMPS ORY AND CAT BACK TUNE DONE BY CHARLES AT GREAD TUNNING!!
TRUE DUALS
05-30-2012, 04:47 AM #6
06-06-2012, 08:23 AM #7
figured out the smoke issue with his.....it was his k&n filter. He's had problems ever since putting that filter on there. He went back to a paper filter and the smoke cleared up. I still haven't had a chance to work on it to try and fix the 87 code though. Might be a while before I get to that.....we both go on vacation next week so I'll be able to at least log his truck then. I'll tune around the 87 if I have too by turning his limp mode off or killing that 87 code altogether.
06-21-2012, 09:01 PM #8
the shim kit for that truck is only $10 also i know it had issues with a injecter wireing rubbing on one of the pigtails but i cant remember what one if you have the efilive see what its reading the rail presser at it coult be the preser sencer is going bad. there was a guy just yesterday on a dmax site that had that happen. if you pulled the plug off of that senser make sure you didnt turn it upside down that will mess things up too. i cant see it needing a cp3 or injecters that year is not known for that stuff that is the older stuff like my 01 lb7. hope some thing i posted helps
06-21-2012, 09:18 PM #9
if you think it maybe just not getting the fuel to the cp3 you can try the tank pic-up mod
http://www.kennedydiesel.com/docs/Fu...ifications.pdf
06-21-2012, 11:06 PM #10
so get this.......he swapped out his K&N and put some injector cleaner in the tank. He hauled it 7 hours each way to VA Beach and back and didn't set the code one time. The temps got up in the 90's each trip. I'm not sure I'm fully convinced it's fixed for good but it definitely made a difference. He normally would've set that 87 code hauling in those temps.
06-22-2012, 08:40 PM #11
i found your post on the dmax site last night when i was looking for this issue and i know the k&n stuff is kind of like it is on here they dont like them.
06-23-2012, 06:37 AM #12
I run basically the same filter with no issues.....his truck though threw a fit with it.
Diesel guys come on in
By blackSS01 in forum Almost Anything GoesReplies: 81Last Post: 05-07-2013, 05:02 PM -
Question for you diesel guys...
By nut6778 in forum Domestics and ForeignsReplies: 13Last Post: 06-13-2009, 05:50 PM -
Any diesel camper guys?
By 02SOMZ in forum GM TrucksReplies: 3Last Post: 06-05-2008, 03:05 AM -
diesel and off road diesel. what the diff?
By greatwhiteZ28 in forum Almost Anything GoesReplies: 14Last Post: 09-24-2007, 07:32 PM -
The Diesel vs a TA
By emrgnc in forum Kill StoriesReplies: 6Last Post: 07-26-2006, 08:14 PM
