Results 1 to 14 of 14
Thread: no brake lights
05-21-2012, 09:12 AM #1Junior Member
- May 2012
- Arkansas
no brake lights
We have a 2001 Bird..we have tail lights,turn signals and hazards but no brake lights except the 3rd light in the trunk lid..we changed all the tail light bulbs and changed the fuse but still no brake lights..any suggestions??
05-21-2012, 03:21 PM #2
Did you make sure it was the right bulb? Any water damage?
Are your front lights working?
I had a similar problem but with my blinker in the back.. make sure all your lights work because one could be triggering and causing your light not to work
05-21-2012, 03:24 PM #3Senior Member
- Feb 2010
- north bay california
Black- 00 camaro ss M6 #6695
make sure you have the right bulbs, some look identical but they will not work, i dont think is the fuse but you might wanna ch4eck that also, o
another guess will be the socket messed up.
05-21-2012, 04:41 PM #4Former Mopar Man
- Jun 2011
- Branchville, NJ
It has to be the bulbs. The brake light switch is working and you have power the the sockets. It's Gotta be da bulbs is wrong.
05-21-2012, 08:55 PM #5
Agree.. Has to be the bulbs or sockets.
Make sure you're getting lamps that have the right part number and contain 2 filoments.
One filoment is high and one is low in brightness on brake lamp indicators.
If you just got tail lamps which are single filoment bulbs they will light up but there will be no high or bright side for braking indication.
05-22-2012, 02:25 AM #6
Interesting issue... if you need schematics posted let me know.
05-22-2012, 02:43 AM #7Senior Member
- Nov 2006
- Indianapolis
This is a classic turn signal switch failure.
If all the bulbs work as they should when you turn on the hazards, and also have the parking lights on to check those filaments in the bulbs, and only the 3rd brake light works, then the turn signal switch has issues 99.9% of the time. I've fixed many like this.
The brake circuit goes thru the turn signal switch except for the dedicated wire to the 3rd eye. Now, since you know about this, when you're driving look at how many cars have a failure like this, I usually see 2 or 3 per year and if I can at the stop light, let them know about it so the gun-toting fine collector doesn't do his thing.
05-22-2012, 05:16 AM #8
05-22-2012, 05:45 AM #9
That switch is a PITA..
05-22-2012, 05:10 PM #10Senior Member
- Nov 2006
- Indianapolis
This check works only when the turn signal/hazard/brake light filament are all the same in the back, like on the 4th gen TA. When they are different bulbs, like an amber rear turn signal, there is a different problem. Lots of Fords have this issue as well, and those combination switches are a lot easier to replace.
05-23-2012, 01:32 AM #11Life is a waste of time, time is a waste of life, so get wasted all the time and you'll have the time of your life.
brake light bulbs
05-23-2012, 03:40 AM #12
It can be. With GM it depends on the vehicle in question some are a better design than others.
Example: My 05 Chevy Equanox and my brothers 07 Chevy Colorado for instance,
we're constantly replacing our tail lamps as there is an inherent design flaw that causes tail lamps to nearly constantly burn out.
Harness, socket and switch issues are a relatively common problem with the 4th gen F-body aswell.
But if you look @ vehicles such as my Hummer you see a far better design.
Everything on my H3 is water proofed..
It was designed to have it's lights and other external electrical componets submerged in water as the H3 can ford 24 inches of water.
Even the doors are double gasketed to keep water out of the cabin.
Hoses and sensors for the induction system are fitted (snap together with fitting lips and clamps) and sensors shielded to keep out water,
and durring those times where it's under water the engine breaths though the raised foe air intakes just ahead or the windshield.
The H3 is also more of a luxury SUV and carried a heavier price tag new aswell.
In the case of my 01 Camaro, I did'nt have any issues with my sockets or switches, but I could'nt keep fog lamp bulbs in it to save my life.
05-25-2012, 09:21 AM #13Junior Member
- May 2012
- Arkansas
Have the right bulbs,no water damage..gonna try the brake light switch first..then the turn signal..thanks for all the help!!
05-25-2012, 05:12 PM #14Senior Member
- Nov 2006
- Indianapolis
Brake light switch won't help, and you will waste your $$$. You already proved the brake light switch is good since the 3rd eye is working.
No Brake Lights ???
By new2dgame in forum Firebird / WS6Replies: 16Last Post: 09-11-2010, 03:47 AM -
ABS, BRAKE, and ASR lights coming on
By JRENIGAR in forum General HelpReplies: 15Last Post: 06-29-2010, 02:05 PM -
ASR, ABS and brake lights on.
By jhenke in forum General HelpReplies: 8Last Post: 04-03-2010, 06:14 PM -
Help: 98 z28 asr,brake and abs inop lights on
By pdiddyz28 in forum General HelpReplies: 3Last Post: 09-20-2009, 01:57 PM -
brake lights don't work
By 01ls1ws6 in forum General HelpReplies: 36Last Post: 02-21-2008, 10:25 AM
