04-04-2006, 12:17 PM #1colemanGuest
replacing the seat belt guide loop(99 TA)
Hello, I'm new here!
The seat belt guide loop on the drivers side of my TA broke last year. It's really annoying, and probably a bit unsafe to be that way. Does anyone know how difficult replacing it would be? It looks like I'd have to take the seat belt out to do it? Also where could I get a replacement guide? Last, is it something I'm better off just having a garage/dealer do, and any idea how much it might be?
Thanks!
04-04-2006, 03:55 PM #2Member
- Urbandale, IA
Red- 2002 Trans Am WS6 (M6)
Picked mine up at the dealership. As I recall, it takes a torx bit (can't remember the size) to get the belt loose and then you can slide the new guide over the belt and attach it to your seat. Re-attach the the belt to the car and you're ready to go. It was about a two minute job.
04-05-2006, 07:00 AM #3agreed... very simple to do
Originally Posted by OhTwo
definintely NOT worth paying someone else to do.
the part is fairly cheap too (maybe 10 - 15 bucks)
04-05-2006, 12:12 PM #4colemanGuest
I'm fine with doing it, I've just never taken the seat belt off of a car before, so I wasn't sure how involved it was going to be. Unless there is some simple way that I can thread the belt through the guide without doing that?
04-05-2006, 06:31 PM #5
nope you just need the torx bit to undo the belt on the bottom just move your seat forward all the way and it is easy to get at. 1 bolt and you are done.
04-09-2006, 08:12 PM #6colemanGuest
Thanks for the replies. The dealer I called is taking it's time getting info for me. Researching on my own I've found this much out, and I think it's accurate:
front seat shoulder belt guide (96-02 coupe), neutral, RH = 16789714
front seat shoulder belt guide (96-02 coupe), neutral, LH = 16789715
front seat shoulder belt guide (97-99 coupe), gray, RH = 16799272
front seat shoulder belt guide (97-99 coupe), gray, LH = 16799273
front seat shoulder belt guide (97-02 coupe), pewter, RH = 16799274
front seat shoulder belt guide (97-02 coupe), pewter, LH = 16799275
I thought I'd give them part #s to speed things along but I am not sure of which is which side. I assume RH/LH is right hand/left hand, but looking at the car from the front or rear?
Also I'm a bit concerned that none of those match the part # stamped on my broken guide(16729477). Do I have the complete wrong part # or just the #s changed?
Thanks!
HOW TO: Replacing a Broken Seat Belt Guide
By BANDITCAR in forum General HelpReplies: 32Last Post: 08-12-2016, 04:19 PM -
Wanted: Ebony Seat Belt Guide
By Ant71130 in forum Parts Wanted / TradeReplies: 2Last Post: 02-10-2012, 05:31 AM -
WTB: seat belt loop Driver side, grey
By KiloVictor in forum Parts Wanted / TradeReplies: 3Last Post: 05-12-2011, 08:22 AM -
Seat belt guide
By Z28_Driver in forum Camaro / SSReplies: 7Last Post: 01-21-2010, 12:38 PM -
replacing seat belt guide
By Formula_LS1 in forum Firebird / WS6Replies: 6Last Post: 03-18-2007, 11:24 AM
