Thread: PAC line output convertor
04-04-2006, 11:17 AM #1Junior Member
- Jan 2006
- Lafayette, IN
Red- 2000 Trans Am
anyone using one of these or a different brand? will this give me a good signal to my amp? Or should I just get a new Head Unit?
04-04-2006, 11:24 AM #2Rock-n-Roller
- Jul 2005
- OHIO Go Buckeyes!
Arctic White- '07 Trailblazer LT
Get a new HU. The signal coming out of the PAC unit is only as good as the signal going into it. Garbage in, garbage out.
I can tell you from personal experience that the stock HU is of VERY poor quality and distorts badly as you turn up the volume.
04-06-2006, 10:53 AM #3Member
- Oct 2005
- Austin, Tx
Black/Black- 2000 Trans Am WS6 A4
isn't the PAC converter almost as expensive as a low-end deck anyways?? may as well just save your money
04-10-2006, 02:38 PM #4I had a line converter for a little over a year and work GREAT! Only reason why I changed my whole line up was due to HU craping out on me!
Originally Posted by jsnone1
The sound was okay for the cheapness of the part and if you have a extra sub and amp laying around it beats the hell out of stripping the whole car and re wiring everything! just my 2 cents .....
99 WS6 Trans AM
Hurst Shifter
Aftermarket Throttle Body
KN Air Filter
Strut Tower Brace
Z06 Rims
04-12-2006, 07:33 PM #5LS1.com Member #271
- Nov 1998
- Macon, GA
Black- 1998 Camaro Z28
I've been using the PAC OEM-1 for my system for about 5 years now and I have NO complaints.
You can check out my system at the link in my sig.Black 1998 Camaro Z28 6-Speed: LS6 Longblock (405 HP) and lots more...
-View:
www.banddirector.cz28.com
04-17-2006, 01:21 PM #6Junior Member
- Apr 2006
- New Jersey
Black/Red Flip- 2000 Camaro SS
The key with using a line output converter is making sure the signal going into it is not clipped. If you grab the signal before the factory amp, and measure it with a scope you will get about 16 volts unclipped. this happened in my car at 15 notches up on the volume knob. If you go higher than this, the signal going into the line adapter will be clipped and sound like "Hammered Ass". Overall though, a new head is always a better sound.
04-17-2006, 02:15 PM #7Rock-n-Roller
- Jul 2005
- OHIO Go Buckeyes!
Wow!, you only got 15 clicks? Damn!, that's worse than mine. I could turn mine up 23 clicks before it would start to clip the signal. I've always said the Monsoon HU was a POS. This just confirms it.
Originally Posted by SSAndrew
04-18-2006, 06:18 AM #8Member
- Oct 2005
- Austin, Tx
quick question...
I'm using an Ipod with the tape adapter... am I better off turning the gain up on the ipod itself, or keeping it relatively the same as, say, the cd-changer volume?
I know that, if I turn the ipod to a higher volume, the headunit isn't expecting it, and will play bass louder than normal... if I turn the ipod down, and the headunit up, it will lower the bass output to avoid damaging the subs (at least it seems..)
but in regards to input signal and clipping... does adjusting the output of the ipod really affect the ouput of the headunit, overall?
I still think the best way is to get an aftermarket headunit and send the RCAs straight to the monsoon amp... seems that the distortion would be much less
04-18-2006, 10:29 AM #9Junior Member
- Apr 2006
- New Jersey
you want the Ipod at the highest volume it will go without clipping, which is usually about 7/8ths of the way up. Usually the monsoon system is a high level input, so you can run the speaker level outputs of the radio to the monsoon amp. Again, i'm not as familiar with the TRansAm as I am with the camaro system and they are different... you have components in the front and they may be crossed over at the amp, I'm not sure.
Help: AEM Uego Output
By 1slowbusa in forum Computer & TuningReplies: 1Last Post: 07-26-2011, 03:38 PM -
Question on Line Output Converters (loc)????
By 5abivt in forum Stereo and ElectronicsReplies: 4Last Post: 05-23-2010, 08:32 PM -
Question: output and drivability
By mark21742 in forum Internal EngineReplies: 9Last Post: 12-15-2009, 03:06 AM -
Rca output
By slpws6ta in forum GTOReplies: 2Last Post: 10-05-2009, 07:05 PM -
Hi Output Alternators
By HDDude169 in forum External EngineReplies: 3Last Post: 07-19-2007, 03:09 PM
