Thread: Manual headlight motor adjuster
05-13-2012, 05:54 PM #1Member
- Jun 2006
- Newnan, Ga
GM LeMans/Luxo Blue- 2001 Firebird Formula
Been working on my Formula all day in the rain trying to restore the correct headlights and fog light that a previous owner totally hacked up. He removed the low beam buckets and spliced 4 cheap Walmart driving lights in their place. 2 lights on each side. One was about 2 1/2 inches and shaded blue and the other was about 3 1/2 inches with crappy blue bulbs. Looked like a nightmare and the light quality was pathetic. Then he removed the factory fogs and rigged up smaller driving lights just like the ones he put for headlights. Nothing was done with any skill...zip ties, cut wires and electrical tape everywhere...nightmare...just finding the headlight buckets was almost impossible and the factory fogs were pretty expensive. Anyhow to shorten the story I have everything all wired and all the lights work correctly but now the headlight motors don't. One gear has been going bad for a few days and I have a brass gear ordered but the other headlight will not go up or down. I manually screwed it in the up position and now it is stuck there. I tried to manually screw the driver's side up but I guess the gear is so far gone it will only go up about 80%. I hear a short click but no grind from the passenger side. When I turn off the headlights they stay in the up position and neither of them grind like they do when the gear strips out. Not sure if when I untangled his rat's nest of wires i somehow disconnected something like a ground...Suggestions where to start? I wonder if he hacked up a ground wire or something. I guess tomorrow if the rain stops I'll hit it after work. What a PITA.
05-13-2012, 06:47 PM #2Member
- Jun 2006
- Newnan, Ga
I realize I was so aggravated that I forgot to ask my original question...The cap on top of the headlight motor that you can turn with a hex...can it be replaced? I broke one...
05-14-2012, 09:14 AM #3Senior Member
- Apr 2010
- Alabama
It can be replaced but you have to buy a complete headlight motor, since it is attached to it.
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
05-16-2012, 07:43 PM #4
Always fun fixing problems caused by prior owners or those that worked on the car for them. Good luck with it.
Question: Manual headlight operation cover
By Vince from Shamwow in forum Firebird / WS6Replies: 1Last Post: 06-06-2012, 04:11 PM -
Headlight Motor?
By Ironwolf in forum Firebird / WS6Replies: 3Last Post: 01-02-2010, 08:38 AM -
Wanted: 97 ws6 headlight motor
By Blue Sun in forum Parts Wanted / TradeReplies: 0Last Post: 07-19-2009, 07:17 AM -
Manual Headlight Adjuster
By Redstaff in forum General HelpReplies: 3Last Post: 07-02-2007, 08:49 AM -
Headlight motor
By BlueBird in forum Firebird / WS6Replies: 0Last Post: 01-18-2006, 06:00 PM
