Results 1 to 13 of 13
Thread: car won't accelerate...
05-09-2012, 07:26 PM #1
It feels like my traction control is stuck on and won't let me push the pedal.. plus it won't downshift and when it did let me floor it short shifted into second.. I'm thinking maybe a traction control issue? I need info!!!):
05-09-2012, 07:49 PM #2Your friendly policeman
- Jan 2012
- Alabama
Bright Rally Red- 2001 Chevy Camaro Z28
Is the Service Engine Soon light on?
2001 Chevy Camaro Z28 A4
SLP cold air intake/lid, SLP smooth bellow, Pacesetter LT's, ORY, Magnaflow exhaust, BMR STB, adjustable Panhard rod, SFC's, LCA's, 1LE sway bars, cross-drilled rotors
05-09-2012, 08:01 PM #3
Yeah but its been on for a while cause I don't have 0'2s..
05-09-2012, 08:06 PM #4Your friendly policeman
- Jan 2012
- Alabama
Get it checked again to see if any new codes have popped. Any other lights coming on?
05-09-2012, 08:08 PM #5
05-09-2012, 08:23 PM #6Your friendly policeman
- Jan 2012
- Alabama
You said you don't have O2 sensors, but do you still have cats?
Check this thread out. Member was having similar issues, turned out his problem was being caused by his cruise control module.
http://www.ls1.com/forums/f6/gas-peddle-wont-go-more-than-1-3-down-165451/Last edited by FinZ28; 05-09-2012 at 08:41 PM.
05-10-2012, 06:07 AM #7Former Mopar Man
- Jun 2011
- Branchville, NJ
Pull all of the codes and post them.
05-11-2012, 11:20 AM #8
Check the MAF or hose connecting it. Seen that plenty of times.
05-11-2012, 07:46 PM #9
No I don't have cats but I'll try to get the codes on here tomorrow morning
05-12-2012, 09:12 AM #10
05-12-2012, 12:46 PM #11Your friendly policeman
- Jan 2012
- Alabama
Did you read that thread I posted above about the cruise control module? Have you tried disabling it to see if it helps any?
05-13-2012, 12:18 PM #12
Yeah but its something mechanical. Cause the pedal resisted when it was off too. But it randomly just came out of it and now its fine.. its done it before and came out of it before too.. Idk what it could be.
05-14-2012, 10:47 AM #13
Mine does the same thin periodically. The follow the throttle cables to the passenger front side of the engine bay. There is a round black plastic cover that pops off. There should be 3 cables attached. Bellow the three cables there are two gears. Mine will get stuck together and I'll have to pop them apart with a small flat headed screw driver... Or take the handle of the screw driver and tap on the metal part. I can send you a picture of what it looks like later if you wish.
Help: stumble when accelerate/rough idle
By godless-phoenix in forum General HelpReplies: 33Last Post: 01-26-2012, 08:05 AM -
camaro hesitaing 2 accelerate & i can't do donuts
By ajonesz28 in forum General HelpReplies: 27Last Post: 04-16-2009, 01:49 PM -
my 98camaro z28 is hesitating when i accelerate
By ajonesz28 in forum General HelpReplies: 2Last Post: 04-09-2009, 09:23 AM
