Thread: 2000 firebird
    May 2012
    texas
    2000 firebird
    2000 firebird
    I tried to match an old clicker and car won't start alarm comes on lights flash doors won't unlock
    May 2012
    texas
    2000 firebird
    i charged batt still nothing I was told to turn ignition key on and leave it on for 10 minutes I did and still nothing
    Are you using the correct keys to the car?
    Your post says 2 different things? I'm asking for clarity.
    If you insert the ignition key and the security light blinks and stays on that is the PassII Alarm system. Your key either needs cleaned up (try first), or the chip in the key is not reading right. You can get a new key from the dealership for about $20 that matches the VIN or you can do the VAT's bypass.
    now if your key is not the problem and it is the key fob not working properly because is a different one then the one you got with the car then it is most likely that the key fob is not coded to match to the car's BCM (Body Control Module).
    The BCM is coded to match you VIN number. That is why you can't open another FB next to you with your key fob.
    I know your next question will most likely be - "how do I get this (key fob) replaced? A - You will need to either buy another one from the dealership or have them reprogram the BCM to the key fob you are using. It's not cheap to reprogram. Last time I checked it was around $190. At replacement fob match to the VIN is much cheaper.
    Member bostonbruins34's Avatar
    Jun 2006
    Newnan, Ga
    GM LeMans/Luxo Blue
    2001 Firebird Formula
    I picked up a replacement/spare fob on eBay for $20 used. There is a code on the back of your fob something like
    Manufacturer Part Number: ABO1502T
    Interchange Part Number: 16245100-29
    The interchange number will vary. The fob I got this number from is an eBay auction selling for $27 shipped. I won't post a link because I have no way of knowing if it will work for your car because of the interchange number so check your number first. If you don't have the original fob I really have no idea how to find which one will work...
    East of Cleveland, Ohio
    99 WS.6 - Modified
    I'm with Scott on this.
    Jun 2006
    Newnan, Ga
    GM LeMans/Luxo Blue
    Let me clarify one thing...you still have to program it to your car but it is really easy. You can finds the instructions online.
    Your friendly policeman FinZ28's Avatar
    Jan 2012
    Alabama
    Bright Rally Red
    2001 Chevy Camaro Z28
    I ordered mine off Amazon. It works most of the time.
    2001 Chevy Camaro Z28 A4
    SLP cold air intake/lid, SLP smooth bellow, Pacesetter LT's, ORY, Magnaflow exhaust, BMR STB, adjustable Panhard rod, SFC's, LCA's, 1LE sway bars, cross-drilled rotors
  1. For Trade: 2000 Firebird WS6
    By egaunnac in forum Vehicles For Sale / Trade
    Last Post: 03-14-2017, 11:49 AM
  2. 2000 firebird 3.8 v6 problem
    By Alcondragon in forum General Help
    Last Post: 06-30-2014, 06:12 AM
  3. 2000 Firebird v6 won't start -- Please help!!
    By jpinto in forum General Help
    Last Post: 11-17-2008, 08:02 PM
  4. Stock Firebird Hood off my 2000 Firebird
    By blackbird04 in forum Parts For Sale / Trade
    Last Post: 09-15-2006, 07:12 AM
  5. 2000 firebird v6
    By 99trans in forum Vehicles For Sale / Trade
    Last Post: 07-10-2006, 12:03 AM
